displaying posts 1 to 25 of 42
Author Subject: Breaking a 95k 2000 phase 3 China
ravemercer
Hi I'm breaking a 95K 2000 phase 3 China
Some parts are boxed ready to post but most parts are still on the car so will need some time to get down to the 6 and whip the bits off. The panels and bigger stuff would be a weekend job.
Location Strood Medway Kent ME2 / Biddenden Ashford kent TN27 Mon-Fri 8am-4pm
Posting wont be a problem for the smaller bits as I'm working close to post office so parts already boxed will be posted next day. Some of the larger bits will be collection only.
Clicking on bold highlighted writing will show pictures
Unavailable parts
Crank, rods, pistons, block.
Drivers wing mirror
Roof lining
Wishbones
Dash frame however all switches, blower, plastics, vents, etc are for sale.
Wheels, Brakes, Suspension, Drivetrain
Pro race 2 16" t1r's £200 Collected
light track wheels lighter that pro race 1.2 some paint flakeing around bolts no kurbing.
Two have 4.5mm - Other two are almost brand new condition.Includes wheel bolts.Direct fit no spacers, missing one spigot ring. 73mm bore to 65.1mm pug fit.
Pro race 2 Pic 1
Pro race 2 Pic 2
Pro race 2 Pic 3
Pro race 2 Pic 4
T1r's Tread Depth
Rear beam complete minus rear callipers £50 Collected
Rear Callipers £25
Brake callipers front new mintex pads and faily new brembo discs £50 Boxed
Bilstien B4 Struts, Springs & Topmounts £20 Collected
Front hubs 18mm £25
Front Hubs 16mm need new bearings £10
Drive shaft D/S £10
Drive shaft P/S £10
Gearbox £70 Collected
Flywheel £5
Exhaust
Exhaust manifold £30
Cat £20
Hoffman centre section almost brand new £10
Magnex 3" exhaust Back box £40
Has some scratches and two small dents came off a Magnex cat back. 76mm tip - sleeve ex 66mm - pipe ex 63mm
Engine Bay
Head Complete Non Tapper £100
Alloy crank pulley complete kit Rich W £80 Boxed
Auto tensioner pulley has brand new bearing, has a mark by the circlp slipped on the press, circlip fits fine. Idler pulley has brand new bearing, has a scratch on the side of pulley.
Auto tensioner with new pulley/Bearing £15 Boxed
The pulley is almost brand new came off a o.e pug auto tensioner. 1k mile on it.
Inlet manifold complete inc all sensors £50
Inlet manifold bare £10
Injectors & fuelrail £10 boxed
Could do with new o rings
Starter motor Valeo £15 Boxed
Alternator £10
Oil catch tank £20 Boxed
Coil packs N'4 £20 Boxed
Bitron Unit
Battery tray/Box £20
Battery tray/Box
Original Airbox without filter £20 Boxed
Original Airbox Boxed
Pipercross venom induction £20
In the process of cleaning this up will post some pics soon. this is the alloy version of the carbon fibre viper.
Locked ecu £40
Unlocked ecu Rich W £60 Boxed
Heat Exchanger £10
Matrix Pipes £15
Top Rad Hose £10
Lower Rad Hose push in type £5
Alloy rad £10 Collected
Fan setup £20
Abs pump £5
Brake servo £10
Power steering Pump £5
Interior
Gear knob £15
Gear knob
Steeringwheel £10
Speedo £10
Glovebox £10
Rear seats £15 Collected
Front Seat rails £10 each
Door cards £10 Collected
Front Light Console £5
Rear Light Console £2
Front belts £5
Rear belts £5
Exterior
Front bumper £40 Collected
Rear bumper £40 Collected
Bonnet £20 Collected
Wing D/S £10 each Collected
Drivers door inc glass £25 Collected
Passenger door inc glass £25 Collected
Boot hatch £40 Collected
Passenger wingmirror £10
Side Skirts £10 Collected
Front lights Crystal £10each - £15 pair
Light are missing there lower fixing point as usual.
Front lights ph2 £5 each
Front lights ph2
Rear lights £10 each - £15 pair
Side repeaters new bulbs £5
Rear Wiper Arm £5
Front Wiper Arms £5
Hocky Sticks £5
Grill £5
Under Tray £40 Collected
Slam Panel £15 Collected
Front wiper motor £5
Rear wiper motor £15
Posted 8th Mar 2013 at 20:17
mike rallye
Intrested in condition of rear calipers and coil packs. If still for sale at the end of the month.
Posted 8th Mar 2013 at 20:26
ravemercer
Ok mate hopefully if its not p**sing down tomorrow ill be getting them off and cracking the nipple make sure there all good, all came of a perfectly healthy car so coils were fine Sagem ones o.e i assume
Posted 8th Mar 2013 at 20:38
ravemercer
Coil packs are sagem in great condition got a receipt for them from 06/2009 £180 they have done about 25-30K
Posted 8th Mar 2013 at 21:06
martinh
Alloy pulley complete kit. What does that consist of mate?
Posted 8th Mar 2013 at 22:16
ravemercer
Light weight crank pulley, auto tensioner pulley and idle pulley with the bracket the full kit rich sold. Both with brand new bearings pressed in last week. Click the writing to see a pic of the kit.
Cheers David
Edit. The auto tensioner pulley and the idle guide pulley are upgraded have better bearings, there soild rather than plastic standard items.
Posted 8th Mar 2013 at 22:22
martinh
Ok mate, im interested. Will let you know if I'll have it tomorrow.
Need to check funds!
Posted 8th Mar 2013 at 23:20
ravemercer
Ok no worries
Posted 8th Mar 2013 at 23:22
spike_uk06
What condition is the rear bumper in? If it is reasonable I will have it! Smile
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 8th Mar 2013 at 23:30
ravemercer
In very good condition iirc i'll double check for damage tomorrow morning. And get a pic up
Posted 8th Mar 2013 at 23:36
RetroPug
PM sent.
Posted 8th Mar 2013 at 23:39
spike_uk06
Ok mate sounds good. Thumbs up
Team China
Team Pirelli
Team Cracked Bumper
92k
ravemercer
PM replied to.
Posted 8th Mar 2013 at 23:50
7057sam
Does the alloy crank pully kit fit a rallye ?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 9th Mar 2013 at 00:24
ravemercer
The alloy crank does fit but I dont think one of the otherd fit you have a different tensioner I can check my mate's rallye possibly tomorrow.
Posted 9th Mar 2013 at 00:33
7057sam
Ok thanks Smile
Rallye dead Sad
Posted 9th Mar 2013 at 01:02
jammamayhew Banned!
shouldn't title be 1999 instead of 2001 mate being a v reg
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 9th Mar 2013 at 07:20
ravemercer
Nope not a 99 It was registered late Jan 2000 title amended.
Posted 9th Mar 2013 at 08:42
spike_uk06
PM Replied to!
Team China
Team Pirelli
Team Cracked Bumper
92k
Posted 10th Mar 2013 at 15:27
ravemercer
Updated with extra Pics
Posted 10th Mar 2013 at 18:54
aaron6
How much just for the panel filter without the box?
I'll also vouch for the head being a non tapper. It sounded sweet as a nut. Wink
Posted 10th Mar 2013 at 19:10
ravemercer
Got some interest in the box and filter if it doesn't go I'll let you know Aaron tenner would see it be spit form the box.
head was nice and quiet cheers for the heads up Smile
Did your mate get a 6 in the end ?
Posted 10th Mar 2013 at 19:19
aaron6
Nah, hes going to get a meg 225 I think. Do let me know though. Id be up for the k&n so I can get a rotation going with the one already in mine which needs a clean. Sad to see this one broken but it'll help out a lot of other 6's as it was a sound car.
Posted 10th Mar 2013 at 19:30
ravemercer
swerving the gti6 club cant say I disagree really I've spent god know how much on them now lol my bianca wont start now ffs ! sorted the bad knocking you heard when you came down. but still got a low down death rattle when I lift off big ends i think Sad
Posted 10th Mar 2013 at 19:36
aaron6
Bottom end off that quiet little china will sort that out. Wink
What was the original noise?
Posted 11th Mar 2013 at 07:56
