Author Subject: Throttle bodies won't run? Video inside
gti6girl
Car was working fine yesterday but today it fires up and idles but as soon as you give it and throttle the engine dies?
http://i147.photobucket.com/albums/r295/gti6boy/D0136CCD-1B57-4B09-8048-0EFD9278BD06-3832-00000591AB9EC156_zps8270beff.mp4
Posted 7th Mar 2013 at 17:35
fordygti
Has the ecu been mapped?
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 7th Mar 2013 at 17:39
Throttle pot would be my first port of call.
Posted 7th Mar 2013 at 17:45
fordygti
Only reason I ask is.cos before mine was mapped it was running really rich and when you went on the throttle it would die.
Posted 7th Mar 2013 at 17:46
daver6
Sounds like a sensor issue, crank? EDIT < Just saw the video > Still sensor related I'd imagine or lambda?
Wishbone Polybushes available
Posted 7th Mar 2013 at 17:57
fordygti
Tell me if I'm wrong, but if its a faulty crank sensor, the engine wouldn't start?
Posted 7th Mar 2013 at 17:59
gti6girl
Lol I gathered its a sensor. It's been running sweet for the last 3 years.
I was debating tps or fuel pressure maybe?
Posted 7th Mar 2013 at 18:09
Who car is that ?
Posted 7th Mar 2013 at 18:13
gti6girl
Car I built for my brother in law Bruce
Posted 7th Mar 2013 at 18:17
Tps would be my first port of call bud ?
Posted 7th Mar 2013 at 18:23
fire up the laptop, should spot it easily enough.
Posted 7th Mar 2013 at 18:57
gti6girl
Not got use of all that anymore. I got to try and fix everything myself these days
Posted 7th Mar 2013 at 19:22
standard laptop should suffice surely? with the right cable of course, what ecu?
Posted 7th Mar 2013 at 19:56
pete_rallye
Definately sounds like a TPS fault. Had mine do the same thing a while back. Even without a laptop you can check it using a multimeter.
Think it'll be an EFi Euro 1 ecu, which I believe needs a silly expensive cable to connect to.
Lap of the 'ring
Posted 7th Mar 2013 at 20:01
gti6girl
Pete is right. The cable is a nightmare to get hold of
I have a brand new tps for my car sitting here which I could donate for a while but it's gonna be a pain trying to get the throttle % set the same
Posted 7th Mar 2013 at 20:10
pete_rallye
Have you tried starting the car on high throttle? When TPS's go faulty its usually only for a short part of the entire range, and mostly at lower ranges as they are used more. Or you could start it and quickly move it past the lower range to higher load points to see if it revs up or not.
Lap of the 'ring
Posted 7th Mar 2013 at 20:21
gti6girl
Put the new tps on and it's back to full power again
Thanks for the help
Posted 8th Mar 2013 at 19:17
Good good glad it's sorted
Posted 8th Mar 2013 at 19:26
Mine takes some throttle when starting when it's been sat for an age. Usually have to maintain some throttle so it doesn't die. Otherwise with more regular use it's fine. It adds character at least.
  • Posted 9th Mar 2013 at 09:13
