Author Subject: eibach springs
ajmckeane
Can you use eibach lowering springs on standard shocks?
China's ALIVE !!!
Posted 27th Feb 2013 at 20:40
Yes
Posted 27th Feb 2013 at 20:47
woody.
I thought it would give a poor ride tho? Dunno
Posted 28th Feb 2013 at 15:26
meoldchina
This was a factory option. Shocks wear quicker apparently but if they've done 100k it isn't really a concern!
Posted 28th Feb 2013 at 15:32
  • Posted 28th Feb 2013 at 16:03
    yes they work just fine, its only 30mm.
    Posted 28th Feb 2013 at 16:04
    I'd say that the Eibach is a better quality spring than the ones fitted as standard. I certainly did'nt feel the ride suffered as a result of fitting them.
    Posted 28th Feb 2013 at 17:18
    woody.
    Sorry wasn't very clear, I was led to believe you should run shorter dampers with -30mm eibach springs or does this not matter? Have heard good things about the springs though.
    Posted 28th Feb 2013 at 17:51
    Niall
    upto about 30-40mm your alright on standard shocks. Any more and ideally you need some shorter shocks like B8s
    Posted 28th Feb 2013 at 18:07
