Author Subject: 5mm solid hub drilled spacers and bolts
Since changing to 330mm brembos I no longer require the set of 5mm spacers I bought to clear the old brake setup. I got the arse with the crappy universal spacers and forked out for ones with the correct centre bore so they sit nicely on the hub.
They are the same as the eibach ones but Un-branded. Also have 6x longer bolts with 19mm heads. Still use locking nut as 5mm won't make that much difference.
They were only on the car for about 3 months and literally covered about 30 miles in that time as the car was off the road for most of it.
Can email pic if needed.
£25 delivered.
Posted 26th Feb 2013 at 14:01
phil b
What brake wheel combo??
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 26th Feb 2013 at 23:38
Had 406 coupe brembos under 5 spoke 17" wolferace suzukas. They were just to tight to fit behind the spokes without spacers. 330mm setup moves the calliper in by 10mm or so. Clears easy now so these are no longer needed with any of my wheels.
Posted 26th Feb 2013 at 23:41
Bumpy
Posted 2nd Mar 2013 at 00:35
valentin
I might be interested in these, basically looking at a set of 17's 7j but with et30 so am wondering if the 5mm spacers will be enough to clear the rear...
Posted 7th Mar 2013 at 18:51
Correct offset is ET15 iirc I run 2 sets of 17's and I'm pretty sure there wouldn't be 10mm of room behind them so I doubt it. Would get hubcentric 15mm spacers if I were you Wink
Posted 7th Mar 2013 at 19:15
