205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread
Looking for:
VTS P1 Rack
PR1.2 16"
| Author | Subject: Braided brake hose |
jamiek_uk2000
From what point of the rear brake line would a new braided line run from, is it from the flexi that runs under the rear beam or do the braided lines replace that flexi aswell?________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Its literally just the rubber flexis you would get from eurocarparts or whatever that get replaced usually.If that makes sense ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
jamiek_uk2000
So there would be the solid line that then runs from the flexi to the caliper as normal?________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
Yup, anything existing that's rubber gets replaced, so the solid lines go straight to your new flexis. The only bit of flex at the back goes between the chassis and the trailing arms:Rears: ![]() Fronts: ![]() ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
jamiek_uk2000
The fronts are only like that on yours due to the Brembo's though? Normal front hoses go straight into the caliper. I suppose I better order some new rear lines then, I may have damaged the original one slightly ![]() They are bent back holding the system full of fluid ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
The only cars that had a flexi line to the rear caliper are the s16 and very early xsi, but that design was soon changed to a solid pipe along the trailing arm and just a flexi around the beam. |
jamiek_uk2000
mr swampy s16 wrote: The only cars that had a flexi line to the rear caliper are the s16 and very early xsi, but that design was soon changed to a solid pipe along the trailing arm and just a flexi around the beam. That would be what I saw fitted then, I was wondering how they converted from the type fitted to my car, anyone know how much those two rear hoses that run from the rear flexi to the caliper... ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
You dont need them, just mwke the hardline longer.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mr swampy s16
welshpug! wrote: thats what fe is on about!!!You dont need them, just mwke the hardline longer. Any local factors should be able to make you them up probs less than a fiver a line. |
