Author Subject: Phase 1 vts rack
pugheaven
As above, after a phase one vts steering rack for the Dimma
Posted 14th Feb 2013 at 20:31
JWP EFi
Turbo Legend!
i think i may have one, its still attached to the subframe and i cant remember if its ph1 or 2
i will check on saturday...whats the number of turns lock to lock?
Posted 14th Feb 2013 at 21:39
pugheaven
2.4 although iirc phase 2's are the same but have Push fit unions for the oil pipes which I DON'T want!
Pics would be goid too ao i can see the condition off the ram and the protective boots!
Thanks
Ollie
Posted 14th Feb 2013 at 22:02
JWP EFi
Turbo Legend!
no probs, i will have a look on sat and send you some pics
Posted 14th Feb 2013 at 22:06
pugheaven
Bump
Posted 19th Feb 2013 at 09:14
pugheaven
Bump
Posted 13th Mar 2013 at 18:21
pugheaven
B
U
M
P
Posted 20th Mar 2013 at 16:25
pugheaven
bump
Posted 4th Jul 2013 at 19:29
Ph2 vts pipes fit straight on the 306Thumbs up
Can pick up the racks cheaper too, and the slight difference in lock is hardly noticeableThumbs up
Posted 4th Jul 2013 at 22:25
pugheaven
Can the phase 2 pipes still be re routed down to the sump area?
Is it just the pipe ends that are different?
Posted 5th Jul 2013 at 06:56
Yeah, just the connection into rack is only differenceThumbs up
I've relocated my pas pump to sump, you don't need to cut the hose from pump to rack eitherWink just reshape it slightly near pump.
Pics in my work thread.
Also another bonus with ph2 pipes is the condition of them, mine were mint and rust free compared to old onesThumbs up
Posted 5th Jul 2013 at 09:07
Think ill have one shortly for sale from a certain 205 Whistle
Posted 5th Jul 2013 at 09:36
midlife
Thanks
Ollie
I'm fairly sure that when you fit a vts rack you put the 6 ram onto it to limit the travel so the wheel doesn't hit the boxDunno
Cool
Team 330™Cool
Team "no front end or engine"
Posted 5th Jul 2013 at 09:52
pugheaven
I wont need to do that as im running wide track Smile
Posted 5th Jul 2013 at 10:35
