Author Subject: 1998 GTI-6 Lock set and ecu's?
Puggie
Hello
Just got my GTI-6 only problem is my brother has lost the keys Thumbs down
So i am wanting full lock set
2x door locks
1x Ignition barrel
1x Boot lock
And i am of the knowledge that i will need the ECU's as well ? is this correct
Has anyone got the required parts ?
cheers
dave
Posted 13th Feb 2013 at 11:05
dendle89
Dont need an ecu just the locks, barrel and ingnition ring !
Team 6 Cylinders
Posted 13th Feb 2013 at 13:55
Puggie
Cheers for the reply been told i need the transponder as well ?
Posted 13th Feb 2013 at 13:57
dendle89
Yea, well your gonna need the key and transponder chip thats a given mate lol
Team 6 Cylinders
Will need an ecu as they are coded to the transponders Wink
Posted 13th Feb 2013 at 14:55
wrong, the ring on the ignition is just a generic aerial, you need the chip and ecu and transponder box.
locks can be from any 306.
Posted 13th Feb 2013 at 14:58
dendle89
Ok, my error thought it be the same sort of set up as the 106 !
Team 6 Cylinders
Posted 13th Feb 2013 at 15:07
it is...
Posted 13th Feb 2013 at 16:43
dendle89
Not on the s1 rallye its not...
Team 6 Cylinders
Posted 13th Feb 2013 at 16:46
in that case it wont even have the ring you're talking about, and this aint no S1 rallye....
Posted 13th Feb 2013 at 17:14
smegal
In summary, you need:
-Keys (with immobiliser transponder chips)
-Locks
-ECU
-Transponder box
Or a properly unlocked ECU so that you don't need to worry about the immobiliser.
A longish woodscrew makes getting the door locks out easy, getting your ignition barrel may be interesting as it needs a key to remove it. The boot is pretty easy too.
Ex SC-6
Now in a Megane R26
Posted 13th Feb 2013 at 17:19
Puggie
so who's got ?
-Keys (with immobilizer transponder chips)
-Locks
-ECU
-Transponder box
Posted 13th Feb 2013 at 18:51
Puggie
seriously no one ?
Posted 13th Feb 2013 at 21:50
ECU's tend to go with engines.
Posted 13th Feb 2013 at 22:13
