Author Subject: Oil level sensor location
ed_doe
Evening all,
Swapped engine looms on my 6 today (long story, the car was running badly due to an intermittent map fault which turned out to be corroded wiring caused by a cracked seal where the loom meets the ecu plug).
Basically all is good except when turned to accessories, the oil level sensor just waves between max and min, and then goes to zero. I'm assuming this is due to a plug not being plugged in correctly, but can anyone pop a diagram up with where the offending plug actually is!!
Ed
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 10th Feb 2013 at 22:32
Carl Chambers
its behind the starter motor in the engine block.
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 10th Feb 2013 at 22:58
The plug itself is green and is as Carl says. The plug itself is located right next to another green plug, this is for the knock sensor on the front of the block.
Posted 10th Feb 2013 at 23:47
ed_doe
Great cheers guys! Typically not the easiest plug to get to! Never mind, I'll have a poke about when I get a chance.
Cheers Smile
Posted 11th Feb 2013 at 07:04
No problem. Thumbs up
Posted 11th Feb 2013 at 16:49
You are very welcome Smile
  • Posted 11th Feb 2013 at 16:51
