Author Subject: Imperfection on head by inlet valve
gti6girl
Just noticed this down one of the inlet valve hole
Car was running sweet before I removed the engine so maybe it's fine. Looks like a small stone has gone through?
Posted 10th Feb 2013 at 16:34
Presume it runs fine? No tapping? If your worried about it then get a compression test done. Will show if there's been any damage at all to the valve seat.
Posted 10th Feb 2013 at 17:00
gti6girl
Was running fine when I run it 2years ago. It's not in a car at mo so want to know whether I should fix first or just put it back in
Posted 10th Feb 2013 at 17:10
If it was running perfect before, I wouldn't worry about it Nick just put it back in. Smile
Posted 10th Feb 2013 at 17:12
Exactly. Can't see it being a problem. Once it's in to the point you can crank it over on the starter I'd do a comp test to make sure it's even on all 4 just for piece of mind Wink. More than likely it's just a poor casting in the head etc and the valve seat is fine.
Posted 10th Feb 2013 at 17:20
aaron6
Did you not run filters?
Posted 10th Feb 2013 at 17:35
gti6girl
No Sad
I will be trying to fit a filter this time round. There's just not much room at all in a 205 with 90mm trumpets
Posted 10th Feb 2013 at 17:45
rallye1999
A friend of mine runs tea strainers on his bodies, might have room for them
Posted 10th Feb 2013 at 23:33
They're more restrictive than a good filter though.
Posted 10th Feb 2013 at 23:35
Use a pair of old tights? Haha
Posted 18th Feb 2013 at 00:19
You will loose power quicker from airborne dust particles wearing the rings and bores than you stand to gain from omitting the filter. Hot air from a non ducted inlet will also rob you of some ponies too. I would definitely try and find a solution to this. Pipercross do a nice ducted throttle body filter that would probably work for you. It's not as sexy as open trumpets, and will rob you of a little induction noise but for the increase in performance and reduced risk of foreign object damage to the engine internals from stones and loose nuts/bolts etc its got to be worth it.
Posted 18th Feb 2013 at 00:56
gti6girl
Yeah it's always been a space problem not me wanting to loose a bit of power
This time round it will be done properly
Posted 18th Feb 2013 at 18:47
Might be worth taking the head off and checking it all over bud ? Better to be safe than sorry Yes
Posted 18th Feb 2013 at 18:55
