Bright 6 Warning Light Module (Horizontal Display version)
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2421_zpsa9083745.jpg
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2422_zpsd99ddc3c.jpg
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2423_zps0ff63317.jpg
The Bright 6 dash display module gives a professional look to any dashboard. Featuring the latest LED technology to give high contrast and definition to the 6 warning symbols.
Warning symbols include -
Indicators
Main Beam
Low Battery Voltage
Low Oil Pressure
Handbrake
The bright 6 is simple to fit and only has 8 wires to connect. Full instructions are supplied
this is unused and still in its packaging. looking for £20 delivered
Longacre Combo Start Switch
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2438_zpsfcc243d8.jpg
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2439_zps63199343.jpg
Longacre heavy duty 40amp Ignition and Start switch all in one. Silver plated contacts, solid brass mechanisms, and tough phenolic bodies. DOWN is off MIDDLE is Ignition On UP is momentary start. Comes pre-wired with color coded harness and flip up, aircraft style switch cover. Simple to install.
Heavy duty 40amp capability
Silver plated contacts, brass components
One switch does all, ignition and start
Aircraft style cover for easy off operation
Pre-wired with multi plug and flying leads
its new and has never been fitted but packaging is long gone and there are no instructions with it. looking for £20 delivered
Two Pedal Box Brake Reservoir Fluid Level Sensor Caps
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2436_zps501492d9.jpg
Info on these can be found here. I bought them to use on my 205 which had a pedal box fitted.
looking for £12 delivered for the pair
Hydraulic Handbrake with no master cylinder
http://i261.photobucket.com/albums/ii73/gcrallying/075638B9-782E-4F35-8528-689DA844434A-1459-0000024C43C0FCCB.jpg
http://i261.photobucket.com/albums/ii73/gcrallying/F0D0463C-C5C0-437B-B631-FE9D060B3520-1459-0000024C49B349A6.jpg
this was to be used in my 205 but was never fitted. the m/c has been taken for my new h/handbrake. looking for £25 delivered
JIC -6 and -8 Male Aluminium Weld On Fitting
http://i261.photobucket.com/albums/ii73/gcrallying/IMG_2435_zps7877fe0c.jpg
bought these from torques and I have got a clue why. looking for £5 delivered for the pair SOLD
Geoff
306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956
