Author Subject: Gear Linakges and Short Shift
306xsi
Hi,
I'm having some troubles selecting 1st/2nd gears, had a look at some previous threads and think the problem lies with the linkages.
Had a look on Ebay, looking at approx. £40 for news ones. Pug1Off do a set for £38 or £55 with a short shift.
Anyone tried the Pug1Off ones?
http://www.shop.pug1off.com/product_info.php/306-gti-rallye-uprated-gear-linkage-kit-short-shift-p-640
Read quite a few contrasting reviews of quick shifts generally, would it be worth the extra £17?
Thanks for any advice.
Posted 29th Jan 2013 at 18:21
24seven
The quickshift pug1off do in that picture looks a lot like the GE quickshift of old, though I can't see quite how it clamps down tight onto the gearbox arm so that might be a worry if it's able to slip. Miles' from here (pugracing on eBay, probably the £40 odd ones you've seen) makes gear rods which are quite highly rated by a number of people on this and other forums - I've used sets on both the 205 and 309 I used to own and no doubt it's only a matter of time before I buy some for my '6.
Posted 29th Jan 2013 at 18:42
Metal gear rods do tighten up the gear selection nicelyThumbs up
I've got a Compbrake quickshift in mine,its a replacement gearstick which is adjustable,very good IMOWink
Have you tried changing your gearbox oil?
Gets over looked on alot of older cars,and having the correct grade in the 6 speed box makes a differenceYes
Posted 29th Jan 2013 at 20:49
Get some from miles Smile
Put some grease on them first too
Posted 29th Jan 2013 at 21:04
miles
I can do that type for next to nothing, but using threaded bar isn't the strongest method at all so I would hate to supply it for it to snap, If your after a set drop me a PM and I can sort that out, Also the Q/S I'm making similar to what Skip Brown do or did but it does involve supplying a new 'L' but again with a new ball this will help tighten everything up nicely
www.pugracing.com
Posted 29th Jan 2013 at 21:33
306xsi
Thanks a lot for the help and info guys. Dropped GE an email and they got back to me straight away saying they had a quick shift I could buy. Very keen on those linkages Miles so I'll drop you a PM!
Changed the gearbox oil a couple of days ago when I put the car back together, used the Pug stuff as recommended on here. Thanks for the idea though.
Posted 29th Jan 2013 at 22:06
hsustyle
Uprated gear linkages make a nice difference!
I have previously fitted a GE type quickshift to the end of my the long gear selector rod, made gearchange notchy and quite clunky and it was a right pain to adjust so i'm staying well clear of those ones from now on.
How about a gear lever one like compbrake and others do? I have one my 106 and it's fully height adjustable and it's very OE looking under the leather gaitor.
Beef Beyond Belief
Posted 30th Jan 2013 at 13:29
Combrake miles gear rods and a griffens quickshift all together equals :-)
Posted 30th Jan 2013 at 18:48
306xsi
The compbrake does look quite smart, gonna give the GE and new rods a go though. Just out of interest, how does the compbrake allow you to select reverse without the lifter? Or is the 6 version different? Thanks again.
Posted 30th Jan 2013 at 20:02
You have to custom fit the lifter mech,bit of a pain but doableThumbs up
Prob the best idea would be to buy a new lift up mech bracket from PugYes
I cut the old one off my old stick and fitted it to the compbrake stick using a hoseclip to retain it.
The other pain with the Compbrake one is you need to drop downpipe off to remove/fit gearstickSmile
Oh yeah and another pain is the collars keep coming looseThumbs down so you need to get them welded to stick once you have got the shift where you like itThumbs up
Posted 30th Jan 2013 at 20:31
miles
Just to add now that the Shorter 2 rods are now adjustable on the car, no more taking them off which can be a pain when new, So the rods have left & right hand threads which is a first so I'm waiting for everyone else to copy me now
www.pugracing.com
Posted 31st Jan 2013 at 20:26
Is that the type you've just sent me from eBay miles? Adjustment on the car? Does that make a quick shift obsolete then as I already have one on the car.
Posted 1st Feb 2013 at 18:22
craig-gti6
I was also looking at getting the pug1off gear linkages so I'm glad this thread came up. Seen as miles item is highly rated ill be ordering a set on Thursday. Are they easy enough to fit as this is one of the jobs I've never done before?
Posted 1st Feb 2013 at 19:37
Old ones can be a bas**rd to get off at times not sure about the miles ones don't think their to bad just have extra clips to hold them on. Think he said they come with instructions.
Posted 2nd Feb 2013 at 19:55
miles
Q/S's are a personal thing, I hate them as it makes the box bulk, a good std linkage set up is all thats needed I think and to go along with this I don;t have any on any of my car's, 205's or 306's.
But I will be producing a adjustable Q/S which is fixed onto a brand new Quadrant 'L' so it won;t be that cheap but you will have a new ball as well which again helps keep it good
www.pugracing.com
Posted 3rd Feb 2013 at 21:51
Miles I received my linkages today but no instructions.... Do you fit the secondary clip after their in place or leave them on? Also what's the best grease to use in them? Normal ML?
Posted 4th Feb 2013 at 17:52
24seven
Take the pin/clip out completely, pop the ball on, push the pin through then clip it around. You won't even be able to get it on with the pin through in the first place, unless the design has changed since the last set I bought from him.
Posted 4th Feb 2013 at 17:59
306xsi
Yeah, that's right. Mine arrived at the weekend (thanks Miles), gonna fit them tomorrow but looks pretty simple. The old ones come off quite easily if you use needle nose pliers to lever them off.
Posted 4th Feb 2013 at 18:04
Taken pug ones off a million times just wasn't sure on the second clips on the new ones. Cheers guys will fit this week.
Posted 4th Feb 2013 at 19:06
miles
The instructions are a point to point list at the bottom of the invoice which is on the front of the package
www.pugracing.com
Posted 4th Feb 2013 at 21:29
monty-69
The gearchange on the Ge "quickshift" is awful, save your pennies
Posted 5th Feb 2013 at 23:19
stilly
these compbrake quick shifts...what is it that you actually get....Dunno
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 6th Feb 2013 at 16:45
Gearstick base, thats made of alloy with a spherical bearing in it, and two collars which you fit to your standard gearstick once the standard plastic ball has been removed from it.Thumbs up
Only downside to it is that the collars need welding to the gearstick to stop them coming looseRoll eyes they come supplied with grub screws in them, but even if you countersink the gearstick and use thread lock on the grub screws they still come looseThumbs down
The pivot point is raised on the compbrake set up compared to the standard gearstick base, so thats how it gives you your shorter shiftWink
Posted 6th Feb 2013 at 18:34
foot
so is the Compbrake quick shift the one to go for then? well once you get the collars welded on.
Posted 20th Mar 2013 at 16:25
phil b
From this piece of toss
To a bespoke copy in mild steel tacked on to stop the bugger spinning
Personally I'd give the g.e p1o one a wide birth, mine couldn't hack the pace at trackdays Ali is too soft also once I had a d/s seal go the oil made it slip hence the tack
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 1st Apr 2013 at 12:33
