Author Subject: Caster gauge and setup
devere
Can anyone recommend a decent caster gauge for setting up my front suspension please.
I've seen the magnetic gauges that attach to the hub. Do these work well and accurately? I don't think I can stretch to a whole setup with degree turn tables etc, so want something that will do the job.
Failing this I shall have to try and hunt a suspension expert form in the local area...
Posted 25th Jan 2013 at 23:16
devere
Is this some kind of unknown dark art or something?
Posted 27th Jan 2013 at 22:16
for most on here with road and simple track cars most likely!
Posted 27th Jan 2013 at 22:19
Tallguy_2
Turntables aren't as hard as they are made out to be...... But what are you looking to achieve?
I've come from a setup and geometrical Motorsport back ground which is handy. The 306 is my first go at doing anything mechanical though really and to be fair I've learnt a lot by experiencing and making the f**k ups myself! But with some helpful info and advice on here it's never been a huge problem!
The best way to learn is simply to have a go, drive it make a change and then drive it again to see what effect it's had
Here's a few bits http://www.motorsport-tools.com/camber-castor-c-17780.html
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 28th Jan 2013 at 23:36
devere
I understand the principles of what to actually do, as in measure from 20 degrees one way, to 20 degrees lock the other way. But whether I could justify the outlay of what it was cost for the turntables is another thing.
I wondered if anyone had used any of the gauges, as ive seen lots of them, and the price varies so greatly from £30 to 2 or 3 hundred. SO If I went for the cheaper end, would I be getting the accuracy, or is the price irrelevant to the usefulness of the tool so to speak.
Posted 29th Jan 2013 at 17:34
Never had any issues with the acculevel gauges, use them for everything from building jigs, building chassis and setting it up.
Posted 29th Jan 2013 at 18:05
devere
Im guessing going by the link posted above you mean the first one you come to.
What do you do with that one then, basically hold it across a flat on the wheel? Or as some others appear to be done, on a hub or disc with the wheel off? That may be a stupid question..
Do you find the turntables absolutely necessary, or can you use a more rudimentary method of measuring out the degrees on the floor, or at least with something cut to a 20 degree angle and working to that?
Posted 29th Jan 2013 at 18:27
midlife
For a focused track car...
TBH there isn't much adjustability on a 6.
Adjustable top mounts, front coil overs (height, spring poundage & damper settings) & at a push tweaking rear subframe & adjusting torsion bars is about it.
You can get the camber/toe changed on the rear beam thoughNinja
You need to make the decision what you want to do with your top mounts, all negative camber, all castor or a mix between the two.
Then get it corner weighted...
Have funThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 29th Jan 2013 at 19:05
midlife
I did end up getting these...
They are extended by 10mm & have slots instead of holes, not the best way to get extra negative camber I agree but I figure if I put a spacer between the driveshaft & hub the same thickness as I increase the track each side I should be able to get away with it...
Time will tell
Cool
Team 330™Cool
Posted 29th Jan 2013 at 19:14
midlife
Oops, I'll stfu, just spotted you have tubular wishbones Ninja
Cool
Team 330™Cool
Posted 29th Jan 2013 at 19:25
All the best 306's have tubular wishones Whistle
Posted 29th Jan 2013 at 20:05
midlife
All the best 306's have rose jointed rear shocks too...
Cool
Team 330™Cool
Posted 29th Jan 2013 at 21:40
