If you aint first, your last!
| Author | Subject: rear wiper intermittent |
spitfire
Regular Location: Leighton Buzzard Registered: 30 Apr 2009 Posts: 365 Status: Offline |
Wiper works intermittently. Is the motor knackered or could it be a dodgy relay.sometimes just restarting th car fixes it.________________________________________ If you aint first, your last! |
I've a relay here if it's suggested to be the cause.________________________________________ ![]() |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
It is unlikely to be the motor itself, as it still works. I'd start by checking the wiring for loose connections and trying a new relay (both very cheap options). ________________________________________ Cherry Rallye SOLD |
spitfire
It being intermittent, and the fact that it works after restarting the car was making me think more the motor rather than relay, perhaps motor brushes are shot? Well check the connectors. Surely if a relay it's duff it's duff?________________________________________ If you aint first, your last! |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
sounds more relay to me________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
spitfire
Will check relay and connectors first. Dan can I get that relay off you?________________________________________ If you aint first, your last! |
spitfire
is it not meant to be intermittent?...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: is it not meant to be intermittent?... Think he means more intermittent as in sometimes it works sometimes it doesn't... ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
spitfire
Yeah sometimes it works and sometimes it doesn't, must be French!________________________________________ If you aint first, your last! |
stan_306gti6
Usually the blue relay located in the tailgate. It gets subjected to leaked water and then tends to fault. Quite a common failure. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
If anything the relay gives it a mind of it's own so it stays on from my experiences.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
thugpuggin wrote: If anything the relay gives it a mind of it's own so it stays on from my experiences. This happens when relay is failing combined with slightly low battery. |
smegal
I have a spare relay if you are after one. Although, I'd day it's the motor or the switch. Mine did the same and I tried a number of relays to no avail. Ended up wiring the motor to the wires so that when you turn the switch all the way over it wipes. ________________________________________ Ex SC-6Now in a Megane R26 |
spitfire
Cheers Craig for the offer, got one coming from Dan though. My money is on the motor but we'll see.________________________________________ If you aint first, your last! |
