Had a look at the pads on the front brakes earlier and there seems to be two wires running to the pads in the caliper. One of them has snapped. What is the function of the wires?
Thanks, Tom
| Author | Subject: Brake pad wires? Stanndard setup |
tomlum
Regular Location: Lincoln Registered: 17 May 2011 Posts: 210 Status: Offline |
Hi,Had a look at the pads on the front brakes earlier and there seems to be two wires running to the pads in the caliper. One of them has snapped. What is the function of the wires? Thanks, Tom |
smegal
They are for the wear indicator. Not overly important. ________________________________________ Ex SC-6Now in a Megane R26 |
tomlum
smegal wrote: They are for the wear indicator. Not overly important. What indicator? |
Brake pad wear indicator.________________________________________ ![]() |
stan_306gti6
Exactly that, not needed at all if you visually check your pad wear frequently. The way they work is, the end of the wire is buried in the pad material and when the lining gets down to where the wire touches the disc it earths through this and brings up a warning light on the dash to tell you that your pads are low...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Before you ask the next question, no it won't matter if you chop it off at the pad. Doesn't need to be plugged in and won't throw any lights or errors in doing so. Get the snips out.________________________________________ ![]() |
tomlum
stan_306gti6 wrote: Exactly that, not needed at all if you visually check your pad wear frequently. The way they work is, the end of the wire is buried in the pad material and when the lining gets down to where the wire touches the disc it earths through this and brings up a warning light on the dash to tell you that your pads are low... Thats what I was after! Thanks Stan |
rikky
i pulled mine out as they seemed to rub the inside of the wheel (205 gti speedlines). no biggie________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
beez_neez_gt
rikky wrote: i pulled mine out as they seemed to rub the inside of the wheel (205 gti speedlines). no biggie Good point there, i was going to fit them like oe but wont bother now as they arent important. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Just out of curiosity, which warning light are these supposed to flag up? The few times I've had pads that actually had these wires and worn down so that they should be doing something, I've not noticed any lights on the dash.________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
stan_306gti6
When you brake you will get an orange light which looks like as follows: (•)The only difference being the circle in the middle is larger. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
I didnt snip mine off tonight, i just pulled then completely out because when i snipped them off there was copper wire there which could get into the brakes and cause squealing which is a pet hate of mine. I do spend a bit of extra time to make sure the brakes never get a chance to squeal, by cleaning and using copper grease on pads. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
24seven
stan_306gti6 wrote: When you brake you will get an orange light which looks like as follows: (•) The only difference being the circle in the middle is larger. ![]() I've literally never seen that before! Not that I've ever needed the warning, I keep an eyes on things like pad and disk wear myself anyway. I wouldn't trust something like my brakes to a dodgy little sensor on any car!________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
craig-gti6
Regular Location: kidderminster Registered: 01 Jul 2012 Posts: 205 Status: Offline |
24seven wrote: stan_306gti6 wrote: When you brake you will get an orange light which looks like as follows: (•) The only difference being the circle in the middle is larger. ![]() I've literally never seen that before! Not that I've ever needed the warning, I keep an eyes on things like pad and disk wear myself anyway. I wouldn't trust something like my brakes to a dodgy little sensor on any car!It worrys me that stan has seen this ecspecially with the power his car has |
stan_306gti6
![]() I haven't seen it on my car! In fact the pads for my Brembos don't come with wiring wires. ![]() However, I have witnessed it a lot in my time on a lot of other Peugeots. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
24seven wrote: stan_306gti6 wrote: When you brake you will get an orange light which looks like as follows: (•) The only difference being the circle in the middle is larger. ![]() I've literally never seen that before! Not that I've ever needed the warning, I keep an eyes on things like pad and disk wear myself anyway. I wouldn't trust something like my brakes to a dodgy little sensor on any car!No real need for them anyway, the brake feel and squeal will be more than enough to let you know they are on there way out, they can tend to make noises as you drive along too. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
stan_306gti6
Also, it's not difficult to just have a quick 5 second gander at the pads as you walk up to the car to get in...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
