displaying posts 1 to 25 of 46
| Author | Subject: Flow Rate pin out |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Guys im looking to find which pin it is on the ph3 gti ecu that provides the injection flow rate signal. Seeing as this isnt used as standard, i doubt anyone would just know but if anyone has any pin out diagrams, that would be good. Also if anyone knows of any other peugeots that use the same ecu, then that would be helpful to know |
vts_tibi
Seasoned Pro Location: Nuneaton Registered: 27 Apr 2007 Posts: 1,194 Status: Offline |
What would you use that signal for?________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Niall
Trip computer from a 406. Ive got all the wiring sorted except for this pin. Ive found it for several other ecu's but not this one mainly because im not sure which one the late gtis use! (magnatelli marelli??) |
vts_tibi
AFAIK all of them use the Marelli IAW.1AP.10 ECU.BUT loads of PSA cars use the IAW.1AP range (from 1.4 Saxos to 2.0 GTI6s), and I've seen a few of these inside and they are all the same, except a few minor differences, and naturally they have different dumps. So you may find the info for a Saxo, 206 or else. ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Niall
Cheers ![]() |
Niall
Worked it out now after a few boring hours of trawling the net. Will put a guide up soon on how to fit a 406 trip computer |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
Spot on mate. Doing it for the d8 or d9 computer? |
Niall
D8. D9 is mainly run off the BSI in the 406 however i am also looking at how easy it would be to fit a 406 BSI as that would open up alot more options but problem there is to pair it with the ecu, i would need a brand new BSI. They do pop up on ebay from time to time for about £50 but depends if i have the cash at the time! |
what kind of signal does it send out?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Niall
What flow rate? Not sure yet. Will find out tomorrow. I would assume just a small voltage. |
vts_tibi
Niall wrote: D8. D9 is mainly run off the BSI in the 406 however i am also looking at how easy it would be to fit a 406 BSI as that would open up alot more options but problem there is to pair it with the ecu, i would need a brand new BSI. They do pop up on ebay from time to time for about £50 but depends if i have the cash at the time! No, not correct. In a normal way you would have to pair a new BSI, but there is a workaround. All BSIs have an internal memory, in a form of a SOIC8 EEPROM, or an MCU. The BSI can be Siemens or Valeo, and the PSA range has the following EEPROMs and MCUs: 93C66, 95040, 95128, 95160 and MC68HC912DG128 MCU. These store all the data necessary data on the BSI, including the PIN code, ECU sync etc... If you know the exact type of BSI found in the V6 406 I can tell you which one it has. First of all you need to locate the EEPROM which you have to desolder, and read it's content out with a programmer. I would advise to get a UPA programmer - works with most stuff. http://www.chinasinoy.com/wholesale/new-upa-usb-programmer-v12-with-full-adaptors-green-color-2047.html For desoldering I use ChipQuick. It's even good for 100pin MCUs, a simple SOIC8 is not a problem ![]() http://www.youtube.com/watch?v=7kyaz4Zrd78 This is available at Farnell, and in other varios webshops. Once you have the dump from the EEPOM on your computer just make a new thread on Digital Kaos, asking the guys to virginise your BSI. They'll basically modify the dump to revert it back to the state it left the factory. You may do this ony your own, but it's loads easier to let the pros do it! - you can even modify the security code, so for example you can write the 306's PIN into the BSI, to achieve an even sleeker install. Once you have th modified dump, write it back to the EEPROM, solder it back and assemble the BSI. And hey-ho, you have a "new" BSI ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Niall
Spot on! I had heard rumours you could do that but never had a bloody clue how. Cheers |
vts_tibi
Actually it's quite easy to do it. Once you have an exact BSI type and number I can quide you through all steps.For example here's a pic I found on my computer of a 307 BSI: ![]() The one you have to desolder is one of those SOIC8s found in the red circle - can't recall which tho. But the type (95160) is written on it. You also have to read these out to get the PIN code, and to adjust the mileage ![]() ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
vts_tibi
On a side note, where did you find the signal for the fuel level? As these trip computers can tell you how many miles you could do till empty.And how will you cycle through the options? ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Niall
I am going to butcher a headlight stalk for the horn button, flip it and put it into the wiper stalk to scroll through. I was going to use a 406 wiper stalk but they are a different style. Wiring is the same so could be good if i could get them to fit as they look a bit nicer!The fuel tank level comes from the dials. IIRC without looking at my notes, you need 4 wires from the dials, 4 from the original clock plug and the 1 from the ecu then it will all work. Only downside is you loose the clock but thats one reason why i would like to fit a D9 display but ive got to work out how they work first! |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
Maybe this well help:![]() 1) CPU TMS374CD13APQQ WX69A196W 2) RAM? HERMESPLUS GSCT38318FD03 CKQF9625 3) EEPROM TI TMS28F512A -10C4FMQ L64A503P 4)DRIVER UDK2559EB 9549 5) SECURITY IC SC370606DW 2094 72M01 X0B9617 |
Niall wrote: Worked it out now after a few boring hours of trawling the net. Will put a guide up soon on how to fit a 406 trip computer ![]() Thats absolutely f**king awsome news mate, I wanted to do this but had no idea how. Thanks and thanks again twice mate Edit: bo***cks, just realised ive got an aftermarket ecu, a dta s60, I wonder if this could be used. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Niall
Well ive now got it all worked out and im hoping my display will arrive tomorrow so if so, will bang up a guide tomorrow. Ive started looking into the D9 one (much nicer and you can retain the clock) and it might not actually be as difficult as first thought. |
vts_tibi
Niall wrote: Well ive now got it all worked out and im hoping my display will arrive tomorrow so if so, will bang up a guide tomorrow. Ive started looking into the D9 one (much nicer and you can retain the clock) and it might not actually be as difficult as first thought. Is that the usual Ecran B display, found in most Pugs from around 2001? Like this: ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Niall
Not sure on the model but yes i believe it is |
Niall
buzzbrightyear wrote: Niall wrote: Worked it out now after a few boring hours of trawling the net. Will put a guide up soon on how to fit a 406 trip computer ![]() I wanted to do this but had no idea how. BTW, are you sure you want to do it? Instantaneous MPG flooring it could make you rather depressive! haha |
vts_tibi
Niall wrote: Not sure on the model but yes i believe it is pic added ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Okay, Niall, we get the point________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Niall
daver6 wrote: Okay, Niall, we get the point Yeah i dont know why that post popped up several times. Rather poor glitch with the forum software! |
Would it be possible to get a fuel and trip computer to work with the dta s60 ecu?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
