displaying posts 1 to 25 of 28
Author Subject: gearbox oil leak
boost
as above seems to be leaking from the passenger side drive shaft any ideas as to what id need to fix cause most place dont seem to have a clue what i mean LOL
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 19th Jan 2013 at 13:35
driveshaft seal?!
Posted 19th Jan 2013 at 13:37
boost
is that what it is cause i went to a local motor factor n all the presumed was the diff seal qhen i clearly explained it was leaking from the shaft and has anyone fot a part number for this ?
Posted 19th Jan 2013 at 13:41
same thing.
Posted 19th Jan 2013 at 13:45
boost
ahh might be why i looked at him as if he were stupid turns out im the stupid one LOL
Posted 19th Jan 2013 at 13:50
Yep, driveshaft seals. Yes
3121 44 and 3121 46 are the two part numbers from Peugeot which you will require. Yes
Posted 19th Jan 2013 at 19:17
f**k that Stan they cost a fortune from pug - you can get the same thing from the bay of e for a lot less Yes
Posted 19th Jan 2013 at 19:24
Posted 19th Jan 2013 at 19:26
Peugeot FTW. They aren't that expensive really. Not if they outlast a s**te pair and save another f**k about getting the car in the air and changing them.
Buy your oil from Pug too. Cheap enough and I always think the boxes feel smoother with it in that crap stuff.
  • Posted 19th Jan 2013 at 19:26
    You can, but I prefer to buy from Pug, that way you know you're getting the genuine article. Yes
    Agree with Dan, Peugeot box oil is the best in terms of gearbox performance and feel IMO. Yes
    Posted 19th Jan 2013 at 19:27
    Yeah because pug only do 75w 90 gear box oil right ?
    You bunch of mugs this is the same argument as per water pumps ? I use none genuine pumps as they get changed way before they break and never had a problem.same with shaft seals never had a problem with the ones off flea bay. But hey it's your money
    What would I know only been here 5 mins Razz
    Posted 19th Jan 2013 at 19:33
    IMO on a job which takes longer than 5 minutes I'd prefer the piece of mind spending a bit more on Peugeot parts.
    Do it once, do it right.
    Those you suggest may not leak, but if they did after a few months I'd be wishing is spent an extra fiver or what ever they are extra for ones from Peugeot.
    In fact I'm going to dig an invoice out LOL
  • Posted 19th Jan 2013 at 19:40
    I've always got my shaft seals from Andrew Page and they are about £7 for the pair, and they are Febi Bilstein ones with the oem part numbers on
    You can get the box oil elsewhere too, no idea why you'd pay double or so just for the sake of it?!
    Posted 19th Jan 2013 at 19:43
    Was a shade under £16 for the pair a year or so ago @ trade.
    Peugeot headed paper FTW.
  • Posted 19th Jan 2013 at 19:46
    Each to there own Yes
    Posted 19th Jan 2013 at 20:00
    75w80 Bowen, not 75w90. Wink
    Posted 19th Jan 2013 at 20:06
    daver6
    I'm with Rikky, there'll be no problem at all with the non-Poogeot-arse-rape parts. Granted, I'd get them somewhere other than Ebay, unless they specify the manufacturer.
    Wishbone Polybushes available
    Posted 19th Jan 2013 at 20:26
    ebay = ripoff, £4 cheaper at my local motorfactor for Febi seals.
    Posted 19th Jan 2013 at 20:56
    beez_neez_gt
    I put some g box oil around where shaft fits kn to help with the seal.
    You need 2 litres worth btw.
    I already bought g box oil when i read pug stuff is best so ill let it run in as engine been stored 3 years then refill with pug stuff.
    Anyone know where to get a magnet type plug for the gbox at all?
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 19th Jan 2013 at 20:57
    I know you can get the seals cheaper elsewhere, factors and the like. However, for the amount of times you are likely to do the job (not very often in my case) I'd just rather have genuine parts which I know are going to last.
    Posted 20th Jan 2013 at 08:20
    boost
    does it make a difference weather i have the original reg number or vin number ? or are they all the same ? i find it hard to get parts from pug cause they always tell me i need the vin number they cant do anything without it they are usless up here mind !!
    Posted 20th Jan 2013 at 11:56
    all the same.
    Posted 20th Jan 2013 at 11:59
    scotzman
    isn't there a magnet somewhere in the box anyway?
    Posted 20th Jan 2013 at 12:05
    yep.
    Posted 20th Jan 2013 at 12:20
