Author Subject: can a 205 gti 1.6 box go in a gti 6?
stevec33
as title ive got a gti 6 track car and the synchro is getting weak on second gear, i had a 205 gti 1.9 with the 1.6 box a while back and it flew due to the lower ratio's. Was wondering if the same can be done with the gti 6 easily and if its worthwhile or not. Any advice appreciated, cheers
Posted 18th Jan 2013 at 12:46
jonnie205
main problem is the Ns drive shaft cup and clutch linkage. Xsara vts is the way to go for 5 speed
Posted 18th Jan 2013 at 12:48
The box fits but I'm not sure the shaft will ? Also you need to change the clutch and flywheel I believe ?
Posted 18th Jan 2013 at 12:51
Put the 306 diff in it - no shaft problems then.
  • Posted 18th Jan 2013 at 12:53
    no shaft problems anyway, its the other way round you get issues.
    Posted 18th Jan 2013 at 13:54
    stevec33
    ok thanks for the replys, are the ratios lower/different in the xsara box to the gti 6? like i said would be great to get some more acceleration out of it if a lower ratio box is a straightforward swap
    Posted 18th Jan 2013 at 14:36
    scotzman
    Not sure what the ratios are but I imagine 1-5 of the GTi-6 box are similar to the 205 1.6 box.
    Posted 18th Jan 2013 at 15:02
    Look them up. You'll be surprised.
  • Posted 18th Jan 2013 at 15:06
    scotzman
    just did Smile
    http://www.205gti.com/techgearboxUK.htm
    Posted 18th Jan 2013 at 15:08
    yup, you're in the right ballpark there with that comment, but 4-5-6 are closer.
    gear speeds @ 7200 rpm on a 4.05 FD for the gti6 box.
    41 64 85 104 126 150
    gear speeds @ 7200 rpm on 1.6 box (4.06 FD, 3.3 of 2.92 1st)
    36/41 64 88 112 138
    all on 195 50 15.
    Posted 18th Jan 2013 at 16:57
    allsmiles
    i ran a 1.6 gti box on a gti6 engine and that those gears were really close, possibly a bit too close
    the xsara box would be the way forward
    i still have a 1.6 gti box(be1) in my shed that i kept for spares
    205 gti6 now sold up, but gonna stick around and see whats what Smile
    Posted 19th Jan 2013 at 03:36
    stevec33
    The thing is i dont mind them quite close as its only going to need to top out at say 120mph really as its a track only car, no point having a box with gearing for say 160mph as your just wasting acceleration. Dosent look to me as though the ratios on paper are that much different 1-5 between the two though? Would the xsara box give me better acceleration? Not really heard of doing that conversion as you'd expect the ratios to be longer with it only being 5 speed
    Posted 19th Jan 2013 at 06:53
    funny quote, given 1-3 are nigh on identical, and 4-5-6 are closer together LOL
    MI16/zx16v ratios @7200 on 195 50 15.
    38 59 86 113 144
    vts ratios
    38 59 86 115 148
    Posted 19th Jan 2013 at 10:34
    stevec33
    Anybody got any comments on the xsara box then?
    Posted 9th Feb 2013 at 15:15
