| Author | Subject: Rear Suspension Arm o/s |
rallyandy54
Newbie Location: Hull Registered: 29 Jun 2009 Posts: 9 Status: Offline |
Just stripped a Gti6 rear axle down, and the drivers side arm is badly corroded where it runs in the outer bearing, so looking for a good s/h arm preferably complete with hub so it's ready to fit. Don't need brakes |
jord294
Think you need a new trailing arm shaft, not a complete arm.The shaft just presses out ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
rallyandy54
Any idea how much the shaft would cost, do you have to buy them from Peugeot or do factors sell them? |
yes to both, or look on ebay.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
If you look at my signature, I build axles.I have quite a few new shafts in stock (just took delivery of bulk order) ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
rallyandy54
jord294 wrote: If you look at my signature, I build axles. I have quite a few new shafts in stock (just took delivery of bulk order) How much for a shaft & both bearings? |
jord294
are you only going to rebuild the one side ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
rallyandy54
Yes, n/s arm and bearings are perfect so no need to waste money! |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
I have a stripped beam £60________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
jord294
i can supply genuine parts inc postage for £130this includes- arm shaft 5176.17 x 1 inner bearing outer bearing seal metal cup (goes over new shaft) metal sleeve (which seal sits in) if you need any other parts to rebuild, they will be extra. i've just given you a price on the basics cheers ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
