Author Subject: Gearbox model/code??
braymond
what is the model or code for the 6speed box? I've been trying to get a cheeky reduced price Quaife ATB but need to know the model as "my man" is only finding be1,2,3 and 4 which apparently are all 5 speed.
Thanks
Rallye-R
Nurburgring article
Posted 10th Jan 2013 at 11:42
all quaife BE's are the same.
gti6 used a BE3/6 and later on were BE4/6
Posted 10th Jan 2013 at 11:44
braymond
In laymans terms, what does the BE refer to for it to be the same?
In terms of a diff, would it make any difference whether it was mated to BE3/6 or BE4/6?
This may be a very stupid question, but I'm very wet behind the ears when it come to transmission.
Rallye-R
Nurburgring article
Posted 10th Jan 2013 at 11:47
On another note, What were differences between the be3/6 and 4/6
Didnt know there were two boxes?
Posted 10th Jan 2013 at 12:08
Rich E Forum Admin
QDF3H is the one you want.
As Mei says it's universal to all BE gearboxes.
Posted 10th Jan 2013 at 12:09
out of interest what changed between the be3/6 and be4/6 boxes? any visible differences or internal difference? interchangable?
Posted 10th Jan 2013 at 12:11
There's some webbing on the case and it's supposed to be stronger. Apparently the ratios differ slightly also. Yeah will fit vehicles originally fitted with BE3 fine.
  • Posted 10th Jan 2013 at 12:20
    what had a be4 then? late p3 6's?
    Posted 10th Jan 2013 at 12:21
    The late 2000 china had one. I'm not sure when the change over period was, although someone will be able to tell you.
  • Posted 10th Jan 2013 at 12:23
    About 98 on.
    Posted 10th Jan 2013 at 13:11
    which is the better one,early or later one?
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 10th Jan 2013 at 13:32
    i imagine the later one LOL
    Posted 10th Jan 2013 at 13:33
    not much difference other than FD in the gti6 box.
    Posted 10th Jan 2013 at 14:04
    The gearbox in my car was originally from a '99 V reg and that is a BE4/6. Yes
    Posted 10th Jan 2013 at 16:39
    How can you tell? I assume there are markings somewhere.
    Posted 10th Jan 2013 at 21:22
    miles
    You will find markings on the case easy as that, The later casing's have some fin's on the end case under it for extra cooling, Better oil ways and a stronger support for the input and output shaft bearings, Bell housings the same pretty much.
    Reverse gear went from Syncro to straight cut again as per 205 box's
    www.pugracing.com
    Posted 11th Jan 2013 at 02:57
    Yeah, mine has "BE4" stamped on the housing at the top near where the crank sensor bolts to.
    Posted 11th Jan 2013 at 21:39
    Ill take a look at mine I seem to be quite lucky with the late bits so far for a Treg
    Posted 12th Jan 2013 at 21:48
