Author Subject: Rear hub fitting.
beez_neez_gt
As above, iv tried fitting new hubs but it wont easily slide fully onto the stub axle and im thinking a drift would pop out the bearing sleves ?
Any tips in fitting them?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 6th Jan 2013 at 17:44
fit the nut.
Posted 6th Jan 2013 at 18:03
beez_neez_gt
It wont go in enough for the nut to go on and push it as i thought about doing that, i have the correct hub as the back washer thing fits perfectly.
Pug fee`ver,
Posted 6th Jan 2013 at 18:06
beez_neez_gt
There is a plastic thing that came with the SNR bearing kit, not sure whats its used for.
Pug fee`ver,
Posted 6th Jan 2013 at 18:10
beez_neez_gt
Android again.
Pug fee`ver,
Tried some emery cloth on the shaft?Dunno
And are you sure you haven't damaged the shaft removing old bearing race?Thumbs down
Posted 6th Jan 2013 at 20:22
beez_neez_gt
Nope i never removed old bearin as bought zx arms to fit, ill use a drift n emery paper.
Pug fee`ver,
Posted 6th Jan 2013 at 20:41
jeffers Forum Admin
Stick them in the oven for ten mins then slide them into place. Thumbs up that's what I did when I built my new beam.
*edit* they're an interference fit do they're not going to just slide on, a bit of heat expands them a little allowing them to slide straight on.
Team Running Engine again!
Team Negative Camber!
Posted 6th Jan 2013 at 21:34
pugheaven
As above and if you can get hold of some use freeze spray on the stub axle.
Posted 6th Jan 2013 at 21:43
beez_neez_gt
Good tips thanks, ill give it a try but the oven is a mile away from the hubs lol.
Pug fee`ver,
Posted 6th Jan 2013 at 21:46
chris with a pug
you need to use a tube drift.
I used a bit of roll cage, but any strong tube will do that fits over the stub axle.
It then just taps into place.
Posted 7th Jan 2013 at 01:18
beez_neez_gt
Ok thanks Chris, i have some spare tube, i was just worried it may pop through the other side, your confimation means ill use that method. The car and beam is off the road a mile away from my oven, so would be pointless doing it that way as it will be cooler by the time i get to the car.
Cheers fellas.
Pug fee`ver,
Posted 7th Jan 2013 at 02:05
beez_neez_gt
All sorted now thanks to Chris, i then used the nut to finish off fitting it on no problem.
Pug fee`ver,
Posted 9th Jan 2013 at 22:58
