displaying posts 1 to 25 of 33
Author Subject: Noisy cam bearing??
footah212
Just got a replacement engine in the car before crimbo due to doing some serious damage to my last one.
The engine originally came from my mate's 6 and then got transfered to our 309 track car. Then engine had been a snapper but everything was fixed and ran in the 309 for a couple o years with no probs at all. The engine was removed from the 309 and has been in storage for approx 4 years( it was turned by hand now and again but not that often if i'm honest)
Anyway its now back in my 6 and appears to be running well, pulls well and actually feels a wee bit better in mid range.
However there is a whining noise that seems to be coming from the cams area at the cam belt end. I had cam belt cover off today and can't see any problem with the belt, tensioner or idler.
I have never taken a head apart before, is it possible that a bearing has dried out of flattened slightly during non use and making the noise?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 20:10
Cam belt to tight ?
Posted 5th Jan 2013 at 20:19
footah212
bigbadbowen wrote:
Cam belt to tight ?
Seemed to be ok for tension. Might lossen it a bit and see if that helps. I am a bit wary of this though since it would appear that a loose belt is what killed the other engine.Sad
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 20:24
JWP EFi
Turbo Legend!
if its been stood for 4 years then i would be replacing the cam belt kit along with a fresh water pump
I'm not a fan of 'loosening' timing belts.
Don't take any chances with belts, better to spend a little money now rather than risking damaging
your new engine
Posted 5th Jan 2013 at 20:31
footah212
your new engine
Sorry should have said the engine got all new SKF belt kit and water pump before being dropped in.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 20:33
honestly3k
No chance of it being the PAS pump? They can sound pretty dubious when they start going
Posted 5th Jan 2013 at 20:36
ryangti6
Chances are then you over tightened it slightly then. Pin it all back up and do it again and it'll probably be fine
Ryan
Posted 5th Jan 2013 at 20:37
JWP EFi
Turbo Legend!
Thats a possibility, run engine with aux belt off if noise disappears then you'll know cam belt is fine
If new kit has just been fitted then as was just mentioned above, time it up and back the tension off a bit
Posted 5th Jan 2013 at 20:39
rich306
To test how tight the belt should be - You should be able to twist the longest stretch sideways. if it goes over a full half turn then it's too loose.
If you can't twist it, then it's too tight!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 5th Jan 2013 at 20:54
your new engine
Skf belt kit Thumbs down should of got gates of dayco Yes
Posted 5th Jan 2013 at 21:08
JWP EFi
Turbo Legend!
^^ Correct lol. Although iv'e got a Conti/dayco kit on mine. When my new engine goes in it will be
a proper Dayco kit, especially as their are now offering up to £2500 towards engine damage should
it break!
Posted 5th Jan 2013 at 21:12
footah212
Initially thought it ma be the ps pump but when listening to the with a makeshift stethoscope it sounds fine. I'll try removing the aux belt just in case. If that don't work I will try pinning the pulleys and slackening the timing belt slightly. It can be twisted about 1/4 turn at the moment. I thought skf had a decent reputation but didn't realise other manufacturers were offering guarantee
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 21:40
100% this. Yes
Posted 5th Jan 2013 at 21:56
JWP EFi
Turbo Legend!
you only get the guarantee if its done through a garage, although, ive fitted many dayco kits to alot
of different cars and never had an issue with them.
Skf are a bearing manafacturer, so bearings will be fine, doubt they actually make the belt though
Posted 5th Jan 2013 at 21:57
footah212
Think the belt itself is continental right enough
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 22:57
footah212
Out of interest is the general rule of thumb 1/2 turn or 1/4 turn for the tension?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 22:59
1/4 I believe
Posted 5th Jan 2013 at 23:13
without force...
Posted 5th Jan 2013 at 23:21
JWP EFi
Turbo Legend!
bigbadbowen wrote:
1/4 I believe
Correct, i tension all belts this way. When i worked for Peugeot dealer years ago, we had the 'seem' gauge, it worked
out at 45 degree twist on longest run
Posted 5th Jan 2013 at 23:24
footah212
Cheers fellas.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 5th Jan 2013 at 23:57
There is no cam bearings, they just sit between the head and carriers.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 6th Jan 2013 at 00:25
Yes, longest run (between inlet pulley and roller) you should be able to twist the belt at least 45 degrees without excessive force but not more than 90 with excessive force. So roughly around 60 degrees with moderate force is correct.
Posted 6th Jan 2013 at 08:05
footah212
guess it can't be fe ked bearings thenLOL
Might change the idler while I'm there
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 6th Jan 2013 at 10:19
No, no bearings as such. However, the carriers and the head are matched. Yes
Posted 6th Jan 2013 at 12:24
So I cant get a couple of carriers to prep paint and just fit to my head?
I have to remove the onesallreday on,
Prep, paint then refit them?
Posted 6th Jan 2013 at 12:28
