Author Subject: rear calipers
boost
anyone know if the handbrake cable can be adjusted from the rear calilers ?? i tried to adjust the 13milll nut under the leaver and snapped it car needs to be mot'd asap as the handbrake leaver comes up to armpit level !
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 27th Dec 2012 at 21:38
Nope only adjusts from the handbrake iirc
Posted 27th Dec 2012 at 21:47
boost
s**t..... can the bolt/nut be replaced or would it tighten itself if i put new pads in as it needs them ?
Posted 27th Dec 2012 at 21:52
You can replace the handbrake mechanism.doesn't take long and is only 4 bolts.
Posted 27th Dec 2012 at 21:54
boost
theres only 3 on this mate 2 at the back of the lever and one at the front its the one at the front ive snapped
Posted 27th Dec 2012 at 21:56
So what exactly have you snapped, the bolt that secures handbrake lever mechanism to the car, or the actual adjuster that tightens the cable?Dunno
If it's the cable adjuster, 10 min job to swap over for one from scrappy, 3 bolts holding complete mechanism to shell once cable is off.
If it's one of the bolts that secures the mechanism to the shell you will need to remove the old one, drill or cut out and replace.
Not sure if you can get to the underside to just use a bolt, if not you will need to weld a bolt in.Unsure
Posted 28th Dec 2012 at 08:35
boost
ive snapped the actual bolt that tightens the cable Sad car was supposed to be going for mot this morning but thats not happenin LOL
Posted 28th Dec 2012 at 08:39
scotzman
how do you snap that?
I have a lever here but I guess you need it sharpish.
Posted 28th Dec 2012 at 08:42
boost
i can snap the most unusal things LOL but before it snapped it didnt make any difference i was told the pivots were seized is this true ?
Posted 28th Dec 2012 at 08:49
scotzman
pivots on the callipers?
yes they could be
Posted 28th Dec 2012 at 08:51
boost
yes mate on the calipers are them the bits the end of the cable sits in ?
Posted 28th Dec 2012 at 08:54
Yes
Although I would have expected the cables to snap rather than the adjuster nut/bolt if the mechanism in the calipers were seized. Yes
Posted 28th Dec 2012 at 14:51
boost
can someone send me a pic of the adjuster bolt it may nit be the one i snapped cause whem i was tighten it it made no difference
Posted 28th Dec 2012 at 18:31
there are no other bolts that could be mistaken for it.
Posted 28th Dec 2012 at 18:59
if its a gold coloured bolt you have snapped/broken you'll need a new handbrake Thumbs up
Posted 28th Dec 2012 at 22:06
Handbrake cable/s could of been snapped?Dunno
And you have tightened the adjuster right down the thread and snapped itRoll eyes
Just to confirm it is the adjuster you broke,were you tightening it from the rear of centre console,parallel to floor of car?
Posted 29th Dec 2012 at 20:50
