Team Moonstone
Team Working Aircon
| Author | Subject: G.I My Moonstone 6 |
rob_humphrey
Regular Location: St Austell Registered: 16 Sep 2011 Posts: 448 Status: Offline |
Post #51
Well just had it looked at and it's not bottom end and is low on oil so gunna give it a service and see what happens________________________________________ Team Moonstone![]() Team Working Aircon |
Post #52
So it might be ok? |
swiftyboi006
Post #53
Either burning oil or u got a leak ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
binkagti
Seasoned Pro Location: canterbury Registered: 14 Oct 2006 Posts: 2,411 Status: Offline |
Post #54
Did not smoke with me, maybe a leak, was full of oil and never went down when I had it, checked almost everyday lol, its a peugeot after all.________________________________________ TEAM Supercharged Rallye |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Post #55
A parking scrape is quite different from a shunt when a car is hit/hits something at speed that often causes damage some distance from the obvious - the force distorts things so it is never the same or pops seams that might start rust etc. A properly repaired parking scrape is not a problem. ________________________________________ Cherry Rallye SOLD |
MCH_GTi6
formerly mch Location: Hayle Registered: 09 Sep 2005 Posts: 2,456 Status: Offline |
Post #56
roland rat wrote: So it might be ok? Went and had a look and from cold start up nothing sounded untoward, took off the oil cap and no mayo but the spray bars didnt seem to be spraying a lot, but it wasnt dry so must be working to a degree, swiped my finger under the inside of the cam cover and no mayo under there either... Its fitted with a catch tank and that was grouted (looked all gunked up and minging) No untoward noises on the short run but it has blown the bottom rad hose off which with limited tools and it being so low I couldnt get back on without risking injuring myself. Once the hose is on and full with water and system bled I will do a compression test to make sure all is ok in that regard.... Recommended clearing out the catch tank, an oil change, check recently changed plugs are tight, new filters (oil / fuel) Not sure why the oil breather has a filter down by the PAS cooling loop but hey ________________________________________ Team Moonstone� Ph3 GTI6Team Rallye |
rob_humphrey
Post #57
It doesn't burn oil or smoke at all just looks likes it need a really good service ordered everything i need from pug today and will get it done over the weekend________________________________________ Team Moonstone![]() Team Working Aircon |
rob_humphrey
Post #58
Car is now SOLD ![]() ________________________________________ Team Moonstone![]() Team Working Aircon |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #59
Shame |
stan_306gti6
Post #60
pugheaven wrote: Shame Agreed. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Post #61
Gave me nothing but grief mate. Hopefully new owner will have better luck with it________________________________________ Team Moonstone![]() Team Working Aircon |
Post #62
Prob was ? I doubt very much it was just lack of oil ? |
pugheaven
Post #63
Don't know how it used all that oil tho as it was full when I sold it! |
rob_humphrey
Post #64
Just thought id let everyone know the buyer of this car was in contact with me last week, the HG failed epicly on him two weeks after he bought it off me. He had the car looked at and the cause of this HG failure was all the head bolts were done up to all different torques. Also the garage said there was no way it was a reconditioned head.________________________________________ Team Moonstone![]() Team Working Aircon |
Post #65
rob_humphrey wrote: Just thought id let everyone know the buyer of this car was in contact with me last week, the HG failed epicly on him two weeks after he bought it off me. He had the car looked at and the cause of this HG failure was all the head bolts were done up to all different torques. Also the garage said there was no way it was a reconditioned head. rob_humphrey wrote: Gave me nothing but grief mate. Hopefully new owner will have better luck with it Looks like that didn't happen, at least you got shot of it and lumped the problem onto an unsuspecting buyer +1 for you. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
rob_humphrey
Post #66
that's one way to look at it mate ________________________________________ Team Moonstone![]() Team Working Aircon |
binkagti
Post #67
Jesus, danposs was the guy who had it before me with all this alleged work he had done to the car, am glad I walked away from it when I did, being made redundant does have its advantages lol. I must have been very lucky because nothing ever went wrong with it for the 5 months that I owned it. Rob did you ever send off the logbook for the car? Or is the new owner doing it?? ________________________________________ TEAM Supercharged Rallye |
