displaying posts 1 to 2 of 2
Author Subject: Air con pipe spring lock tool
In order to seperate the rather long air con pipe by the engine mounting, a spring lock tool is apparently used.
Is there 'another' way this can be undone to re use or does it specifically require one of these specialist tools?
  • Posted 17th Dec 2012 at 16:20
    Rich E Forum Admin
    Anything that you can get inside the joint to push the release spring will work.
    I recall Pete telling me he'd once done it with a small piece of pipe cut down the middle and pushed into the joint.
    Posted 17th Dec 2012 at 16:41
