Author Subject: Basic engine rebuild / freshen up ?
Moonstone6
Hi fellas i recently won the engine off ebay for £41 Big grin which had been removed due to oil in the water i am going to rebuild it and replace the rings,bearings bolts n seals n belts....lick of paint and pop it in mine Thumbs up is this a good idea just looking for a freshen up
Where is the best place to get the parts from ?
And any ideas what causes the oil in the water im hoping its just the exchange cooler @ the oil filter
(common fault on the fords)
what are your thought Dunno
Posted 11th Dec 2012 at 20:41
dcc
Peugeot... and headgasket failure.
205 GTI
Xsara HDI
Posted 11th Dec 2012 at 20:47
rob_humphrey
HG Failure usually Yes
Team Moonstone Big grin
Team Working Aircon
Moonstone6
perfect in need of a skim aswell then Thumbs up
Posted 11th Dec 2012 at 20:51
Set aside at least £500 for doing it properly. By the time you've got gaskets, head bolts, sealants, oils, fluids, rings, a head skim, valve stem oil seals, belts, water pump etc. Plus any special tools you may need for the job.
Posted 11th Dec 2012 at 20:53
Moonstone6
yes iv already got that covered just wondering weather crank will need grinding n polishing Dunno
Posted 11th Dec 2012 at 21:27
JWP EFi
Turbo Legend!
at least get it polished, approx £40 for engineering firm to do it
Posted 11th Dec 2012 at 21:28
swiftyboi006
Not really any such thing as a basic engine rebuild No
Black p3 Love
Posted 11th Dec 2012 at 21:30
JWP EFi
Turbo Legend!
depends how bad it is to start with
Posted 11th Dec 2012 at 21:31
Do you know the mileage it's done?
Bore condition will make a massive difference to your costs, rings and hone being the cheapest, all the way to a full re-bore and over size pistons.you won't know untill it's strippedThumbs up
Make sure you get the valve guides checked when the head is stripped,mine needed 8 exhaust valve guides due to wear.
Posted 11th Dec 2012 at 23:05
JWP EFi
Turbo Legend!
mileage isnt too much of an issue, within reason. its more down to the maintenance
as coskev said, you could get away with a light hone and new rings, look for wear ridge at top of bore
Posted 11th Dec 2012 at 23:08
JWP EFi
Turbo Legend!
also the old bearing shells will give a good indication of condition, look for 'taper' wear and scores
which will indicate a neglected engine
Posted 11th Dec 2012 at 23:11
Moonstone6
yea mate this is it Ionly paid £41 for it all so if it's b, e, r...... il just sell manifold n pas pump n alternator n get my 40 nicker back Thumbs up
Posted 12th Dec 2012 at 14:24
Moonstone6
absolutely spot on mate all about the maintenance and has it been thrashed from cold every day on the same oil for the last 10 years Shock
Posted 12th Dec 2012 at 14:28
Moonstone6
I hope there is my mate had an old nova a few years back smoking its arse off n drinking oil..... he honed bores and replaced rings seals n bearings and it never used another drop of oil and it was nippy again
Posted 12th Dec 2012 at 14:34
Pugjim pretty much did 90% of the work on mine but would love to do it again! Big grin
bit of a twat getting the piston's back in without the piston rings wanting to pop back out,.. Sad
Posted 12th Dec 2012 at 15:54
JWP EFi
Turbo Legend!
piece of cake if have a piston ring compressor
Posted 12th Dec 2012 at 22:00
i loved building mine with paul. its great fun but as t99pug said check the bearings and crank. better still just replace the bearings. these engines are known for the bottom end going after a head rebuild.
Posted 13th Dec 2012 at 07:59
720puggti
I've done a rebuild and it was a lot of fun, in fact I'd consider it my forte when it comes to mechanics.
As a result I can promise you'll spend more than you think, but when the engine starts you'll feel immensely satisfied.
I would change rings and big end bearings and main bearings depending on condition. Also, do a proper job on the head smoothing as much of the rough casting out and getting rid of all the carbon.
I find mild acidic floor cleaner is best for cleaning all the internal components, mine came up looking like new
Look here: http://www.306gti6.com/forum/showthread.php?id=102699
My engine suffered the same failure as the one you've just bought and I believe it's still running to this day after I finished with it; I fit it to someone's rallye.
I'm sure you'll have fun bringing it back to life Smile
Deepak Gohil
Posted 13th Dec 2012 at 08:25
720puggti
Oh, also, soak everything in oil; except for the the outside of the shell bearing.
And I mean SOAK!
Deepak Gohil
Posted 13th Dec 2012 at 08:27
Moonstone6
Thanks mate very useful advise yes I want to De carbon and polish the inlets and outlets and i will replace the bearings throughout I can't wait Thumbs up
Posted 13th Dec 2012 at 10:37
Don't polish the inlets.
Posted 13th Dec 2012 at 14:30
Moonstone6
why dude?
Posted 13th Dec 2012 at 14:33
no need, if anything you will make flow worse, leave it to the pro's Thumbs up
Posted 13th Dec 2012 at 15:11
Agreed, slightly rough ports give the incoming air slight tubulence which mixes with the fuel better in the combustion chamber. Yes
Posted 13th Dec 2012 at 15:20
