Let me know if you have/know of one!
Martin
| Author | Subject: peugeot partner/citroen berlingo |
martinh
Seasoned Pro Location: Bideford Registered: 08 Dec 2006 Posts: 1,274 Status: Offline |
As per title, I'm after a partner/berlingo for my dad has his has just died! Preferably a 2 litre hdi, would consider a straight diesel but definitely don't want a 1.6 hdi!Let me know if you have/know of one! Cheers Martin |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Whats wrong with the 1.6 Hdi's then? gutless?________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
no, lots of issues.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rich306
Explain? i'm looking at getting a Peugeot Partner somepoint early next year! ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
Mainly turbo and injector related issues, oftten leading to self destructing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
martinh
Exactly as welshpug says! as far as I'm aware mainly turbo issues, my mate has a garage and he quite often has either the 1.6 hdi's and ford 1.6 tdci's in with turbo issues, not a cheap thing to put right either. I'm led to believe that the 2l hdi is a much safer bet! |
miles
Don;t touch a 1.6, I'm not into Derv's but I've seen quite a few of these broken with the garage behind me________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
rich306
Oh right, that's interesting. I had a 1.6 HDi Citroen Xsara Picasso in the past, and that was generally ok whilst i owned the car. Something to bear in mind though thanks ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
maybe
Regular Location: Leicester Registered: 15 Jun 2009 Posts: 385 Status: Offline |
The turbo's only go because people cut corners and use the incorrect engine oil. Service history is the key or go new! |
budget? |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
turbos go due to blocked oil feed return pipes, they should be cleaned/replaced every 40k miles and correct grade engine oil used and changed every 8k miles. Also suffer from egr valve failure and there £200 to buy a new egr valve. Other than that they are a great engine.Rebuild kit for turbo is around £120 and about 2 and half hour job so not that bad as long as you dont carry on driving them when turbo is on its way out. |
