Author Subject: door fitting
LAP1988
Does anyone no how to adjust the drivers door? Just put a new one on but it's sitting proud. I've moved the lock on the pillar but doesn't seem to make any diffrence! Also both widows no longer work. Any ideas?
Posted 5th Dec 2012 at 18:43
rich306
I used to loosen the bolts a little bit (on the hinges), close the door and open it again. That usually made it sit better and then i could do the bolts up.
Did both windows work before you replaced the door?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 5th Dec 2012 at 19:28
ian7675
Techno Viking
I tried adjusting a door on my old 6 and in the end I lost my rag with it. It was a replacement door after getting broken into in Spain and the new one just never fitted right. Whatever I did it always had a very slight wind noise coming in....I traded the car in soon after LOL
Less than 24 hours to go!
Posted 5th Dec 2012 at 19:30
Get someone to help you line it up, and keep making miniscule adjustments evertually you will get it right.
Dont settle for ok either you can always adjust it a bit better!
Posted 5th Dec 2012 at 19:36
Moved to Exterior. Smile
Posted 5th Dec 2012 at 19:39
LAP1988
The new door come with the window and wiring already in it. Didn't think to ask if it worked but my n/s window worked but isn't now! The mirrors both work tho.
Posted 5th Dec 2012 at 19:49
Mine was the same.
Makes it a lot easier.
Btw do you know the trick for swapping the locks?
Could save you twenty minutes at least
Btw if both windows no longer work then the drivers switch cable is loose or the reg isnt plugged in proper.
Posted 5th Dec 2012 at 19:50
broken wiring between body and door somewhere is most likely.
Posted 5th Dec 2012 at 19:53
Im just thinking of when i removed the reg on the old door to prop up the window with wood (pikey i know)
It killed of the other window too until the new door was on.
Posted 5th Dec 2012 at 19:56
LAP1988
I taken the loom out of my original door so going to try that. I haven't changed the lock yet so any tips would 've helpful!
Posted 5th Dec 2012 at 20:05
LAP1988
Sorry about the writing it my phone!
Posted 5th Dec 2012 at 20:06
I'm in agreement here. Yes
Basically for the locks get a wood screw about 3 inches long
Look at the door near the lock where it catches on the shell ( as you look at the barrel follow it around the edge of the door )and theres a small rubber bung .
Pull this out and carefully put the screw in until it makes contact with metal.
Turn the screw a few turns with a screw driver and it will catch in the clip holding the lock in place
Pull the screw and you will feel it unclip.
You can then turn the lock barrel 180 degrees (it should be very loose) to the right, pop the old lock in and then push the screw until it clips the barrel back in place
undo the screw
Refit bung
Jobs a good un
Posted 5th Dec 2012 at 21:27
LAP1988
Alright cheers chap I'll give it a go.
Posted 5th Dec 2012 at 22:48
calibra306
You only have to ask. Yes the windows and mirrors and locks all worked.
You will probably find that where you have removed your original door you have disturbed the wiring harness between the body and door ie the bit you unscrew from the door. Very common problem!
V6 Power!
Faster I can go the better!
Posted 6th Dec 2012 at 22:42
calibra306
If ya still struggle mate let me know and i will send you the hinges as may be a slight difference between yours and the one from the door? Just a thought?
V6 Power!
Posted 7th Dec 2012 at 07:03
