Author Subject: Need a ~125mm diameter 6-rib pulley, with a centre bore <19mm
As above, anyone know offhand of a 6-rib pulley with ~125mm OD, with a centre around 25-30mm thick and preferably <19mm bore in the centre (I need to machine it for a taper fit onto a 3/4" shaft).
Or one close enough so I can press a centre in anyway, some of the newer 1.6Hdi pulleys look about right but the centres are only ~10mm thick so too short for the taper fit (need 25-30mm).
Be nice to find one I can adapt rather than make one from scratch.
Posted 2nd Dec 2012 at 15:29
24seven
You could have made your own in the time it took to type that out!
Posted 3rd Dec 2012 at 00:00
I could, if I had the lathe hooked up and not stuck in a shed under a sheet...
Posted 3rd Dec 2012 at 00:07
get on it Razz
Posted 3rd Dec 2012 at 14:49
