Author Subject: Advanced inlet cam timing??
tom28
hi guys, i have been told the inlet cam on my six has been advanced, can anyone give a proper explaination of what this means, and what effect it will have on the car, (fueling ect) compared to a Normally timed engine.
thanks
Tom P
Posted 29th Nov 2012 at 09:59
it means its very clever and has an higher IQ that another engine of its age Thumbs up
Posted 29th Nov 2012 at 10:13
tom28
ORLY? LOL
Posted 29th Nov 2012 at 10:18
it means the timing has been advanced by a couple of degrees / teeth when it was last done to, in short terms, provide a small gain in power. but really small.. i know the foreigners do it but run mad stuff like ethanol etc so would notice more gain for them i suppose
Posted 29th Nov 2012 at 11:52
Yep, it is supposed to give slightly more power and slightly lower down the rev range too. Yes
A few members have done it here although with the ridiculously small running clearances you have to be careful when doing so.
Posted 29th Nov 2012 at 13:12
I thought that was retarding that did that, Or maybe I have it wrong...
Posted 29th Nov 2012 at 13:37
^^You are wrong and that is retarded Laugh
Posted 29th Nov 2012 at 13:41
advance = spark after tdc
retard = spark before tdc
Unsure
Posted 29th Nov 2012 at 13:45
noooo LOL
just means the inlet valves open and close earlier.
Posted 29th Nov 2012 at 14:06
LOL
We're talking about valve timing not ignition timing...Doh
And even then, the more advanced the ignition timing the spark would be before TDC so you've still got it the wrong way around!
Posted 29th Nov 2012 at 14:18
ah yes i thought we were talking about wrist watches
2 wrongs do make a right though so technically i got it bang on
i've always been a "leave it the f**k alone and don't even look at it when it comes to engine timing" type of girl
Posted 29th Nov 2012 at 14:22
I don't think there is much to be gained in reality, my valve timing on the boosted engine is at standard settings and that's where it will be staying. Yes
Posted 29th Nov 2012 at 18:55
Ahhhh p**s!
Posted 29th Nov 2012 at 18:59
tom28
next question would the fact that the inlet cam has been advanced cause the car to use more fuel, THAT is the burning question
please discuss
Hmm
Posted 29th Nov 2012 at 22:15
No.
End of discussion
Posted 29th Nov 2012 at 22:24
no, less if anything, as it will produce more torque, meaning smaller throttle openings required at cruise.
Posted 29th Nov 2012 at 22:26
Do you have an issue with fuel consumption then?
Posted 29th Nov 2012 at 22:37
tom28
yes its been getting worse the past few months
Posted 29th Nov 2012 at 22:40
JWP EFi
Turbo Legend!
i played with the inlet timing, felt more torquey (a little) didnt see a difference in fuel consumption
when i did this the engine lost its kick at 4500, but as said, i felt it was more like an 8v earlier on
weird as that may sound
Posted 29th Nov 2012 at 22:44
Best check cts sensor,then lambda I'd say
Posted 29th Nov 2012 at 22:49
tom28
T99PUG wrote:
i played with the inlet timing, felt more torquey (a little) when i did this the engine lost its kick at 4500
mine definately hasn't lost its kick, she rips your face off past that level, but now i've owned her for coming up to a year, theres been a noticeable difference in fuel consumption from when i first got her...
Posted 29th Nov 2012 at 22:52
tom28
you have confirmed what i thought was the correct course of action as most probably both these are very tired by now
cheerz rat boy
Thumbs up
Posted 29th Nov 2012 at 22:56
JWP EFi
Turbo Legend!
that could be down to a few different things, lambda, coolant sensors etc, how do yu know that timing has been advanced?
Posted 29th Nov 2012 at 22:59
tom28
carl grimsley off of here (mechanical repairs) made me aware of this alteration after he changed the cambelt for me quite recently
Posted 29th Nov 2012 at 23:03
tom28
it does explain why she drives like she does though
Posted 29th Nov 2012 at 23:04
