Author Subject: Annoying Rattle
rich306
When i first got the Rallye i fiddled about and replaced the downpipe - Cat clamp. Ever since then it has rattled against the Heat shield up by the Cat. Crazy
Whatever i do, i cannot seem to position the exhaust so that it sits away from the heat shield!!!
I've also moved the centre clamp too. Damn things annoying now!!
Any tips or something i can do to shift the cat away from the heat shield?? Sad
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 28th Nov 2012 at 19:22
mpieczko
Check that one or more of the heatshield retaining bolts haven't sheared off.
They have a tendency to do that and it means that a portion of the heat shield will end up sitting closer to the cat that it would normally.
Posted 29th Nov 2012 at 18:23
rich306
The heat shield is fully bolted on, its the cat sitting in too close... i'm just getting fed up of adjusting it now for it not to work. can it twist on the Manifold - Cat join?
- Top Tip!!!
Posted 29th Nov 2012 at 19:44
Edit
misread first post..
Posted 30th Nov 2012 at 18:51
calibra306
Buy a short length of exhaust heat wrap and wrap part rubbing against heat shield. Cheap off ebay for a few foot plus metal ties.
V6 Power!
Faster I can go the better!
Posted 1st Dec 2012 at 14:12
yes, not a lot but it can help, slacken the joint to the centre box and give the downpipe a good wiggle.
also make sure all the mounts are 100%.
Posted 1st Dec 2012 at 14:30
rich306
Thanks guys, will fiddle about with it when i have a spare few hours (without freezing to death in the process)
- Top Tip!!!
Posted 1st Dec 2012 at 18:43
That's all very well but it shouldn't be touching in the first place therefore there is a problem which needs resolving rather than masking up. Yes
Posted 2nd Dec 2012 at 17:26
rich306
i'll get it done properly Big grin Not skipping round the problem..
- Top Tip!!!
Posted 2nd Dec 2012 at 20:36
calibra306
For sure! Better to permantly resolve the problem!
V6 Power!
Posted 2nd Dec 2012 at 20:43
phil b
I had this problem on track with my scorpion bum bottom mount will cure this in future
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 2nd Jan 2013 at 00:55
rich306
I managed to sort it in the end, I jacked up where it bends in the mid section and loosened the bolts to the Cat, shoved a Screwdriver handle in between where it was rattling. Then gave the whole system a good shake to settle it into place.
Tightened it all up and then took everything away. Rattles no more! Razz
- Top Tip!!!
Posted 2nd Jan 2013 at 12:01
Clapping
Nice one, well done for sorting it. Smile
Posted 2nd Jan 2013 at 12:04
