Author Subject: 2.1 S16 engine (185 bhp atw on GTi-6 plenum)
doof
It's done 5 - 10k miles since it was built. It made 180+ bhp at the wheels at the rollers with Sandy. That was on a standard GTi-6 inlet so with ITB's it'd be near 200bhp at the wheels I'd think. Certainly a strong engine.
Spec is:
S16 block bored to 87mm
diesel 88mm crank
forged wiesco pistons
shot peened rods
arp rod bolts
balanced bottom end
taylor engineering stage 3 inlet cam and stage 1 exhaust cam.
flowed head - not sure who did the work but I bought it off a forum member just after the work had been done.
powder coated rocker cover
Plenty of pictures here in the project thread http://forum.205gtidrivers.com/index.php?showtopic=88528
Looking for £1200. May split bottom end from top if there's no interest.
Thanks,
Lewis
Posted 28th Nov 2012 at 12:24
jammapic
Daft question to some I'm sure, but will this run on GTi-6 management?
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 28th Nov 2012 at 19:24
Not without a map
Posted 28th Nov 2012 at 19:48
doof
I would say this will almost certainly need to be running on a standalone ECU. I had it running on a DTA ecu and was due to stick some ITBs on before buying a new car altogether. If you went somewhere like chip wizards you might be able to get the standard ECU remapped but to be honest I'm not sure.
I've got ITB's for sale too which would be suitable. £600 including air filter and manifold.
jammapic
Do a deal on the whole lot?
Posted 28th Nov 2012 at 19:51
doof
for £2200 I'd let the whole lot go.
Engine, including all ancilliaries like starter, brand new alternator, injectors.
DTA S40 Pro ecu with loom used in 205 gti but would likely fit 306 with ECU in glovebox
colin satchell / sandy brown ITBs with manifold and air filters
Posted 28th Nov 2012 at 20:01
Hang on, So this is like 225hp at the fly? Or there abouts?
Posted 28th Nov 2012 at 20:33
doof
I'd think so. Must have been over 200 on the gti6 plenum if it was 185 at the wheels. On itbs it should be getting on for 225 or more at the flywheel. Hard to say really. All i can say for sure is 185 at the wheels when I had it mapped.
Posted 28th Nov 2012 at 20:35
Nicee....
Posted 28th Nov 2012 at 20:39
soton_s16
What would the capacity be, if the 88mm crank wasn't used? 2045cc? Would that fit into the 2litre or under class as it is below 2050cc so would be rounded down? Or am I talking crap? LOL
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 28th Nov 2012 at 21:13
it would be pointless buying this engine to do that with it.
Posted 28th Nov 2012 at 21:22
