displaying posts 1 to 25 of 48
Author Subject: URGENT: ELECTRICAL FIT AND NO HEADLIGHTS
aaron6
Right. I have not used the car for 2 weeks but had a friend start it every 3 days. One day she tried to start it and the battery was dead so she jump started it. I picked the car up today and it was slow to start but fired and and was fine. I thought I'd drive it for an hour to charge the battery and when I flashed a car the power seemed to drain, the car misfired and then it settled. I thought maybe it needed a longer charge. So carried on driving it. Then I used the full beam and the car misfired very badly, all the lights on the dash went mad as did the outside lights. Then the headlights died. So I got it home. The engine was running okay but still no headlights.
I have changed the bulbs, checked all the fuses under the steering wheel and under the bonnet. All seem okay.
When checking fuses I noticed that the battery terminals were loose. Now I guess the connection got to a stage of intermittency and it has f**ked something. I also tried an ecu reset.
Any ideas? I seem to be thinking it's a blown ecu or something.
Posted 27th Nov 2012 at 22:10
doubt it's blown ecu atall
I'd be more tempted to check the battery cos it might have had it. just jumping and/or taking it back out doesn't mean it's now fully recharged. it might be fubar and its losing voltage
Posted 27th Nov 2012 at 22:13
aaron6
I did think that but it seems to be holding a charge, the full beam fires up still so I'd have thought it would have the juice for main beam. Could a knackered battery just stop the front fogs and main beam? All the other stuff like the a/c, heated window and blowers all work at the same time. Dunno
Posted 27th Nov 2012 at 22:26
mellowr1
id take it off,fully charge it,test voltage then.
batterys can do funny things when knackeredUnsure
Posted 27th Nov 2012 at 22:48
aaron6
I don't have a charger. Sad
Gonna get it to a garage tomorrow I think.
Posted 27th Nov 2012 at 22:52
No not if it runs and drives. Had battery's mess about causing all sorts of faults before but not an individual fault not possible. Sounds like a poor connection which may have popped a fuse or relay or burned out a wire.
My mk1 dturbo years ago suddenly lost its live to the dipped beam for no reason out the blue. The wire lost continuity ap just bridged it from the back of the fuse box
Posted 27th Nov 2012 at 22:58
aaron6
What's the best way to fault find as I'm useless with electrics?
Posted 27th Nov 2012 at 23:04
jeffers Forum Admin
It does sound like your loom has developed a fault, or maybe a dodgy earth...... Do you possess a multi meter?
Team Running Engine again!
Team Negative Camber!
Posted 27th Nov 2012 at 23:09
mellowr1
i haveUnsure
Posted 27th Nov 2012 at 23:10
midlife
An auto electrician Dunno
I had an intermittent electrical fault on a 309 GTI years ago, I took it to An auto electrician & he couldn't find any faults, as I drove it away it did it again so I took it straight back, four guys dived on it with meters & 2 mins later they found a live wire behind the radio that was moving around & shorting which was causing all my problems, a £40 well spent me thinks.
Your problem does sound to be battery/alternator so let a professional look at it as you could save a fortune....
Cool
Team 330™Cool
Team "no front end or engine"
Posted 27th Nov 2012 at 23:14
darzmat
Could be a duff connection on your indicator/ headlight stock
Posted 27th Nov 2012 at 23:48
woody.
A bit unrelated but my mum's mondeo started doing this and turned out to be a coilpack or ford equivalent. Maybe try unplug them one by one? Dunno
Posted 28th Nov 2012 at 00:41
aaron6
Random. I will be taking it to my usual garage today. If they can't find it I will have to take it to an auto electrician as I'm useless with multi meters. Sad
Posted 28th Nov 2012 at 06:00
If it was me, I would check all fuses, both in the cabin and under the bonnet and then I would inspect as much loom as you can see for visual damage.
Furthering on from this I would test the battery voltage and do a "drop test" on it to see what voltage it drops to to ensure the battery is working correctly.
I suspect you have a mixture of worn out battery alongside a damaged loom wire or earth, which has had a bad connection, arced and now burnt out. Yes
Posted 28th Nov 2012 at 07:18
rich306
I'd definitely clean up the earths before you do anything else, then search the wiring loom. Where it's been sitting around, corrosion is possible.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 28th Nov 2012 at 07:41
It's only been sat for a couple of weeks whilst he's been on honeymoon. LOL
Posted 28th Nov 2012 at 08:37
have you actually done anything since sorting out the battery terminals?
Posted 28th Nov 2012 at 09:02
aaron6
Checked the fuses again but that's it. I know next to nothing about electrics so wouldn't know where to start. I am poppingIt in to my local garage for a little look today if they have time free. If they find no problem I will need to call an auto sparky I reckon. Problem is see, without the car working I can't easily get to work so whatever it costs I gotta stump up. Sad
Posted 28th Nov 2012 at 09:33
aaron6
What's a drop test? Also, does anyone know a decent car sparky who is in and around the maidstone area?
Posted 28th Nov 2012 at 09:43
drop test is a battery condition test.
Posted 28th Nov 2012 at 09:45
aaron6
Ah, I have put all ideas onto the garage so hopefully they'll have time to look at it. Smile
Poxy cars! LOL
Posted 28th Nov 2012 at 10:20
playboyb
I would have a look if I was home mate, hope Hugo gets it sorted Thumbs up
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 28th Nov 2012 at 10:38
Well, good luck with it anyway Aaron. Thumbs up
Posted 28th Nov 2012 at 11:00
aaron6
Cheers. I may come back asking for more advise this week but you never know, it may be something stupid. Smile
Posted 28th Nov 2012 at 11:01
stilly
have you tried the actual switch....it could have a broken wire inside...Dunno
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 28th Nov 2012 at 12:41
