310 Renaultsport bremboDecat - stainless
K&n
Coilovers
Atb Lsd
| Author | Subject: slimline rad and fans |
brids 306
Regular Location: lancaster Registered: 17 May 2009 Posts: 117 Status: Offline |
Hi all I am going to be fitting nissens rad with slim fans and was wandering how you wire second fan on the aircon button thanks in advance ________________________________________ 310 Renaultsport bremboDecat - stainless K&n Coilovers Atb Lsd |
eddy_gti6
You need to bypass the brown a/c plug. Think its connection 1 and 3 in the plug________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
What he said ![]() ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
eddy_gti6
![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
As above, wire fans to standard wiring then bridge pins 1and 3 on air on pressure sensor! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
JWP EFi
jeffers wrote: As above, wire fans to standard wiring then bridge pins 1and 3 on air on pressure sensor! that looks like 1 and 2 |
Think its the angle though________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
eddy_gti6
T99PUG wrote: jeffers wrote: As above, wire fans to standard wiring then bridge pins 1and 3 on air on pressure sensor! that looks like 1 and 2 Small plug you know ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
JWP EFi
looks like far away pin is empty so to me that suggests 1+2i may well be wrong though |
Rich E
brids 306 wrote: Hi all I am going to be fitting nissens rad with slim fans and was wandering how you wire second fan on the aircon button thanks in advance Out of interest, why do you think you need a manual control? ________________________________________ Rich |
jeffers
T99PUG wrote: I'm sure I bridged 1and 3, I'll have to check now! looks like far away pin is empty so to me that suggests 1+2 i may well be wrong though ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
eddy_gti6
Go on get the torch out lee ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
brids 306
Eventually gonna be charged so to be able to put second fan on if/when get sat in traffic.________________________________________ 310 Renaultsport bremboDecat - stainless K&n Coilovers Atb Lsd |
jeffers
eddy_gti6 wrote: Go on get the torch out lee ![]() Erm no! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
brids 306 wrote: Eventually gonna be charged so to be able to put second fan on if/when get sat in traffic. why? just let the temp senders and relays do their job. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brids 306
Thanks for photos can any see why this is a bad idea??________________________________________ 310 Renaultsport bremboDecat - stainless K&n Coilovers Atb Lsd |
