displaying posts 26 to 49 of 49
Pages (2): 1 [2]
Author Subject: Engine sounds like a aeroplane
^^Good call. Yes
Posted 29th Nov 2012 at 07:01
Demograffix.com
From what the guy on eBay has stated, the replacement one is one that has been removed by switching ignition on. Is there anything I should be aware of when fitting this type
stevenage black gti 6, 198bhp
Posted 29th Nov 2012 at 08:07
Demograffix.com
It was removed from a rallye and going into my
6
Posted 29th Nov 2012 at 08:09
In that case you're best off leaving your ignition at the 2nd click when you fit it, it will still be 'unlocked' then and you will be able to use it.
When you next switch off the ignition the ECU will now become locked to your car and will only ever work on your car again unless you unlock it again in the same fashion. Yes
Posted 29th Nov 2012 at 08:54
Demograffix.com
Here's where I'm at now, I fitted the rallye ecu and started the engine, I also replaced the three cubed sensor on the fan unit, unfortunately I think I may have locked ecu when replacing the sensor as It would have been paired to the old ones. As the engine would not start up I have put the old ecu back and she starts fine now. I'm thinking its the relay sensor and I have ordered a second hand one off eBay. Is there anything I should be aware of when fitting this part, does the ignition have to be switched on, also where can this sensor be located, I read somewhere it was under the nearside front wheel arch is this correct
Posted 4th Dec 2012 at 14:23
When you say 3 cubed sensor - do you mean the 3 relays at the top middle of the fans?
'Bitron' unit? Yeah - it's under the arch liner. Look up by the horns and you'll see it. Held on by 2 8mm nuts.
  • Posted 4th Dec 2012 at 14:32
    Demograffix.com
    Yeah that'd be them the three relays located on the fans
    Posted 4th Dec 2012 at 14:49
    Demograffix.com
    Cheers dangti6 I will have a go at the bitron unit when it arrives, do I have to keep the ignition switched on when removing and replacing?
    Posted 4th Dec 2012 at 14:52
    Nope, just remove and replace. Smile
    Posted 4th Dec 2012 at 14:54
    Post #35
    no that's quite incorrect.
    what the OP needed to do was disconnect the transponder unit or the aerial for the system, what you advised the OP to do has locked his ecu.
    Posted 4th Dec 2012 at 15:12
    Post #36
    Doh
    Your right, apologies, I didn't tell you to disconnect the transponder unit inside the dash before the fiting the new unit...Sad
    Out of interest, why did you want to change the ECU in the first place if the other one was working?
    Posted 4th Dec 2012 at 18:42
    Demograffix.com
    Post #37
    the mechanic said i had all sorts of problems with my ecu, but i have never noticed anything major. Is there anyone who would be able to unlock the rallye ecu on the cheep? as I might need one in the future? gonna try the bitron unit for now just waiting for it to arrive. basically both my fans are on full blast and then one stops and other remains on full blast on start up and running
    Posted 4th Dec 2012 at 18:47
    Demograffix.com
    Post #38
    oh and just for future references wheres the transponder and what does it look like. Im new to fixing problems on cars but gonna try and learn
    Posted 4th Dec 2012 at 18:49
    Post #39
    The transponder unit sits in the dashboard, just in front of the centre console. Yes
    Essentially, it's behind the ashtray. You would need to remove the centre console and then you can get to it easily. Smile
    Posted 4th Dec 2012 at 19:05
    Demograffix.com
    Post #40
    I'm looking for the temperature sensor, I know it's near the thermostat has anyone got a diagram
    Posted 10th Dec 2012 at 13:29
    Post #41
    Which temp sensor, the blue one for the dash or the green one for the ECU?
    Both are located on the thermostat housing next to each other. Yes
    Posted 10th Dec 2012 at 13:59
    Post #42
    probably after the brown one given the fans aren't working properly, that's with the other two.
    Posted 10th Dec 2012 at 14:30
    Demograffix.com
    Post #43
    It was the green one, I found it and looks to have fixed the fan issue, I'm so happy my cars back on the road. I'll see how she goes, thanks for everyone's help. When I unscrewed the old one a load of water leaked out is this normal?
    Posted 10th Dec 2012 at 14:52
    Post #44
    Yes, it is normal. It's due to the fact that the temperature sensor is measuring the temp of the coolant and therefore needs to be submerged in coolant. Wink
    Posted 10th Dec 2012 at 15:50
    Demograffix.com
    Post #45
    I literally unscrewed the old one and screwed in the new one, I wouldn't of caused any air locks by doing this? Should I of bleed the system first?
    Posted 10th Dec 2012 at 15:59
    Post #46
    green one will not have done anything to the fan issue unless it has the wrong plug on it.
    Posted 10th Dec 2012 at 16:02
    swiftyboi006
    Post #47
    Would it not make the ecu think its not hot enough to kick the fans in?
    Black p3 Love
    Posted 10th Dec 2012 at 19:31
    Demograffix.com
    Post #48
    I have run the car last night and when the temp reaches 97 degrees the fans come on and it cools to about 90, so seems to be working. I might change the other two sensors aswell just because they have not been changed
    Posted 11th Dec 2012 at 07:12
    Post #49
    No, the engine ecu has nothing whatsoever to do with cooling fans or the instrument cluster, hence having green for ecu, blue for dash brpwn for fans.
    Posted 11th Dec 2012 at 07:40
    Pages (2): 1 [2]
