| Author | Subject: Few wheel questions |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Back standard height or slightly lower? mine was going to be -20 to kind of match the eibachs________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
eliotrw wrote: Back standard height or slightly lower? mine was going to be -20 to kind of match the eibachs Lowered to match eibachs With 21mm bars and Koni shocks.could see them catching more if I had standard bars and shocks. ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
demondriverdan
Do the 15" TDs require spigot rings? ![]() ________________________________________ Rallye Race Car |
It's got nothing to do with the size, it's the fitment they were originally ordered in. If they weren't made for a 306, they'll need spigots and possibly spacers.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
demondriverdan
owain wrote: It's got nothing to do with the size, it's the fitment they were originally ordered in. If they weren't made for a 306, they'll need spigots and possibly spacers. Aha, fair enough. Hoping the ones I'm interested in should be ok as they are direct fit! ________________________________________ Rallye Race Car |
I'd check before buying them if I were you. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
demondriverdan
Will do!________________________________________ Rallye Race Car |
Spigots are not really a problem, it's the ford offset ones that require spacers I would stay away fromThe plastic ones only melt on track cars that are given a big hammering, no chance of melting them on a fast road car ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
demondriverdan
Looks like the ones I'm interested in do need spigots, not spacers. Not ideal, but shouldn't be a massive problem? This is for the track car though.________________________________________ Rallye Race Car |
Post #35
demondriverdan wrote: Looks like the ones I'm interested in do need spigots, not spacers. Not ideal, but shouldn't be a massive problem? This is for the track car though. Get some alloy Spigots, job sorted ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #36
Yeah, if you're using them for track you'll need ally ones, not plastic. Not only that, but it does make it all a bit more fiddly if you're changing wheels about a lot, I'd seriously considering getting some in the correct fitment.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
demondriverdan
Post #37
I will do in the long run, but they'll be better than the spacers I'm currently having to use on the Dotz!________________________________________ Rallye Race Car |
Post #38
That it definitely true.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
demondriverdan
Post #39
Massive PITA trying to line up 1.5mm spacers either side each time!________________________________________ Rallye Race Car |
Post #40
Didnt think you could get spacers that thin :O________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
demondriverdan
Post #41
eliotrw wrote: Didnt think you could get spacers that thin :O Will grab some photos when I'm back down South. Makes the track of the car a little too wide to be ideal for the trailer as well, so another reason to be shot of them! ________________________________________ Rallye Race Car |
Post #42
Do they not flap about in your hand?________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Post #43
should sit on the bumpstops without catching if you got the right ones and the beam is good.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #44
owain wrote: I'd seriously considering getting some in the correct fitment. I don't honestly think they are worth the extra price for direct fit to hub centre bore Aprox £200 more a set of 4 for correct centre bore. Correct offset and alloy spigots if your using on a track car,plastic spigots are fine for fast road use welshpug! wrote: should sit on the bumpstops without catching if you got the right ones and the beam is good. Depends on the tyre sidewall style if your running 205/45's I had Dunlop SP2000's on mine which did not catch,but now on Dunlop SP Sport Maxx they will catch slightly as above. Just cause tyres are the same size does not mean they are physically identical in size ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
blandy
Post #45
got a quote today of £455 for a set of 4 direct fit from the supplier 15x7 et15 65.1cb |
Post #46
Bargain.I guess 16's are nearer 600 then. Cant go wrong with that! ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Post #47
eliotrw wrote: Bargain. I guess 16's are nearer 600 then. Cant go wrong with that! My 7x16's ET15 were £400 brand spanking off E-Bay Hence why I say I personally would not pay £200 more for the correct hub bore ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #48
I think that price is pretty lucky though? Correct bore ones can sell for 400 plus used id say?________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Post #49
coskev wrote: Spigots are not really a problem, it's the ford offset ones that require spacers I would stay away from The plastic ones only melt on track cars that are given a big hammering, no chance of melting them on a fast road car howcome? i have ford fitment wheels with a spacer ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Post #50
buzzbrightyear wrote: coskev wrote: Spigots are not really a problem, it's the ford offset ones that require spacers I would stay away from The plastic ones only melt on track cars that are given a big hammering, no chance of melting them on a fast road car howcome? i have ford fitment wheels with a spacer Just don't like spacers Can cause wobbles etc too ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
