displaying posts 1 to 25 of 61
Pages (3): [1] 2 3
Author Subject: Embarrassing problem -help sought
hampstead
So I sold my red Rallye thsi evening and the poor chap didn't even make it home before the car stopped and couldn't be restarted. It turns over OK.
I'd like to help him sort it out.
I had the car for nearly 2 years and it always worked fine for me. This evening it was hunting for revs slightly at idle, and even stalled once, which it's never done before. Drove fine otherwise, though.
So what should we check? A read of a few threads gave me this list for starters -
- Spark plugs and leads
- Throttle body electrical connections
- Lambda
- TPS
- MAP sensor
- leaking manifold
All suggestions gratefully received. Thanks.
Matt
Posted 16th Nov 2012 at 23:59
gti6girl
Tdc sensor in top of gearbox would cause this problem, £20 new
Posted 17th Nov 2012 at 08:07
swiftyboi006
Could be a number of things, maybe crank sensor
Black p3 Love
Posted 17th Nov 2012 at 08:11
Crank sensor would be my first port of call too. Thumbs up
That's bad luck for the new seller, not even making it home. LOL
Posted 17th Nov 2012 at 08:13
tvrfan007
Hmm
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Nov 2012 at 08:15
hampstead
Yeah, I feel terrible about it. Hope we can sort it out quickly.
Thanks all for suggestions so far.
Matt
Posted 17th Nov 2012 at 08:18
Fuel pump relay?
Posted 17th Nov 2012 at 08:26
tvrfan007 wrote:
Hmm
Doh
LOL
Posted 17th Nov 2012 at 08:48
eddy_gti6
Crank sensor will stop it starting or maybe coilpack?
Posted 17th Nov 2012 at 08:52
footah212
Sounds like you got rid of it just in time. Lol. Defo check fuel and spark
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 17th Nov 2012 at 09:11
rich306
How unlucky is that! Sad i hope he gets it sorted.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 17th Nov 2012 at 10:10
As above, check for fuel and spark.if both are not there try crank sensor, as when this fails the ecu does not know the engine is turning over so does nothing!Wink
Posted 17th Nov 2012 at 13:44
hampstead
Bit of an update.
All sensor connections seem to be plugged in properly. The car starts and runs, but is hunting and missing quite extensively at idle and stalled when coolant temp around 75 deg C. It can be started again, though, but continues to start and miss.
So does that make the crank sensor less likely, lambda, MAP and TDC sensors more likely?
Thanks.
Matt
Posted 17th Nov 2012 at 17:08
hampstead
Can't edit. Start should say hunt
Matt
Posted 17th Nov 2012 at 17:12
godders
Evening all,
I am the "poor chap" as mentioned in the first post. A cracking start to Rallye ownership hey!
So, everything is pretty much as Matthew has described. Was missing slightly and hunting yesterday evening, but nothing hugely worrying. Drove home absolutely fine til just around the corner from my house where I stopped at traffic lights. They went green, I pulled away, and the car didnt want to play. It coughed, stalled, and then absolutely refused to start for the next hour and a half. So ended up towing it back to my garage!
The first thing I noticed when opening the bonnet was that this yellow plug was disconnected, which, unless I'm mistaken, is for the TPS. The clip on it is broken so I assume it just worked its way loose. But reconnecting it had no effect at all.
Then I had to shoot off to work a night shift. This afternoon I tried starting it again, and besides a tired battery, it fired up without issue. But this missfire was far more pronounced. It is a little slow to respond to throttle inputs but once it picks up it seems to rev smoothly. I recorded a little video to demonstrate.
First port of tomorrow is to check the spark side of things, plugs, leads and coil. But as this is my real first experience of the Peugeot drivetrain, is there anything else I should be looking for in particular?
Map Sensor/ICV are the first things that spring to mind. Are they prone to failure, and would it cause these syptoms?
Any help massively appreciated. I would very much like to enjoy my new car (and drive to work)!
Rob
Posted 17th Nov 2012 at 17:52
no thats not the TPS, just the throttle heater which you can leave off.
Posted 17th Nov 2012 at 18:04
Either a dodgy lambda sensor or MAP sensor at work here. I'm leaning towards MAP to be honest. Yes
Posted 17th Nov 2012 at 18:10
godders
Ah right okay. Is it a case of I should leave it off or I just can if it wont stay on?
Is there a way of testing the map sensor other than switching it with a known good one?
Posted 17th Nov 2012 at 18:16
see the FAQ.
Posted 17th Nov 2012 at 18:22
see the FAQ.
Here: http://www.306gti6.com/forum/showthread.php?id=80340
Thumbs up
  • Posted 17th Nov 2012 at 18:26
    godders
    Well, searching the FAQ's would have made sense really wouldn't it... I apologise!
    Thanks for the link. Will test that tomorrow too!
    Posted 17th Nov 2012 at 18:29
    Usuall suspects are
    Idle control valve
    Throttle position sensor
    Map sensor
    Lambda
    Coil pack
    Power steering sensor
    Fuel relay
    Posted 17th Nov 2012 at 18:53
    I would whip the plugs out and check themYes
    See if they are all the same colour/conditionWink
    Posted 17th Nov 2012 at 19:42
    Chris28190
    Welcome to the endless hassle of owning a gti/rallye Thumbs up
    Cherry Rallye '99 - Sold
    Posted 17th Nov 2012 at 19:45
    godders
    Thanks for the ongoing help guys!
    I've read there are two types of coil setups on the 2.0l engine. 4separate coils and one complete unit. Is that right? If so which one is mine? 1999 Rallye T291 KCK. Looking through the service history the plugs were renewed in Feb this year and the MAP in late 2008. No mention of coils though so its got to be up there on the list of possibilities!?
    I'll throw a new set of plugs in there anyhow, and do an oil and filter change. Try and bribe it into working!
    Oh god. What have I got myself in to!?
    Posted 17th Nov 2012 at 20:04
    Pages (3): [1] 2 3
