Cheers Steve.
MMMM you won't like this but I just love Citroens!!!!!!!
| Author | Subject: Pair of home brew bilstein coilovers £250 with springs and |
talbotsteve
Regular Location: millom Registered: 06 Dec 2003 Posts: 335 Status: Offline |
Built using impreza inserts in hybrid subaru peugeot bodies and 2.25 coilover conversion. Springs included will be the blue ones brand new 12" 350lb. Brand new alloy top mounts. £250 collected from Cumbria or arrange your own courier.![]() ![]() Cheers Steve. ________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
What adjustments do these have other than ride height, rebound, dampening etc |
talbotsteve
No just ride height and the strut tops are castor camber adjustable. the bilsteins are canisters and are rebuildable.....________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
what's the damping rate of the inserts?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
talbotsteve
Unsure just those issued by Prodrive. Unlike the inverted bilsteins on a group 4 escort which have the damper rating stamped in the top these are a canister insert similar to the later peugeot sport suspension and they have no markings, the damper is quite firm and with the 350 rated spring would make an excellent fast road track setup. I have tried them against some 300/120 gpn cossy inserts I have and the feel and rebound is much the same, and they came off an irish tarmac set up escort cosworth, mainly used for single venue stuff so firm but not knock your teeth out type stuff.... Steve. ________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
pugheaven
what is the maximum that it can lower a 306 by if you measured from the sidesill, only reason i ask is as i have a dimma im wondering if that setup would beable to give me the drop i require, i know that i could change the spring length but i still think i will need short inserts?? |
You'll need raised inner arches if you want to go low on a Dimma.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
Iv seen how nur is doing his but i dont intend to go that low, a nice 2-2.5" gap would be nice, still have the problem of the roll centre kit hitting the rotors so it would be good to know if the brake setup he is selling will give me the extra clearance due to the offset and these coilovers give me the required drop i require. |
talbotsteve
The ride height is dictated but the spring height, this kit with my wide arch kit on the xsara was just about right, due to big arch clearances I needed adjustability as I was running out of damper length on standard struts and lowered springs.________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
talbotsteve
Still here.________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
talbotsteve
Bump. Back up forsale.________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
talbotsteve
Bump.________________________________________ MMMM you won't like this but I just love Citroens!!!!!!! |
