Author Subject: Four wheel alignment
anth
Need mine doing badly, since the clutch was done it's been out.
How does this sound price wise..
"We have the hunter 4 wheel alignment system, front toe alignment is £30.00, front and rear toe is £50.00, camber and caster adjustments are charged at £10.00 per adjustment thereafter.
The initial check, is free of charge."
Posted 9th Nov 2012 at 20:41
pete_rallye
There is no camber or caster to adjust assuming you've normal top mounts. nor any rear toe adjustments. So £30 sounds about right! Although you can do it yourself with some fishing line and a ruler!
Lap of the 'ring
Posted 9th Nov 2012 at 20:46
anth
Sorry isn't for the 306, for the lcr, not sure if they are adjustable mind you either.
Posted 9th Nov 2012 at 20:47
pete_rallye
Ah, ok. I don't know if the rears are adjustable or not. I'd say up to £50 sounds ok, but £10 per adjustment for camber and caster could get expensive. I'd check though as not many cars have adjustable camber and caster.
Lap of the 'ring
Posted 9th Nov 2012 at 20:53
daver6
Probably quite good as there's nowt to adjust on the 306 and that seems reasonable, so I'd imagine if they had more to adjust, the price would be fair
Wishbone Polybushes available
anth
Thanks mate, I do have a £10 voucher too Big grin
Posted 9th Nov 2012 at 20:54
anth
Fronts fully adjustable but rear is just toe. Will give it a lash I think.
Posted 9th Nov 2012 at 21:04
Any better setups than standard to look at? Certainly my impreza was a huge amount better after being setup more aggressively.
Posted 9th Nov 2012 at 21:26
My local Motorsport college is going to corner weight the 205 for £50 all in. I think that's fairly good value.
  • Posted 9th Nov 2012 at 21:37
    anth
    Apparently this is standard, can't find any more settings. Worth printing these off and giving it to them you think?
    Front
    Toe-in. 0°, +/- 10'.
    Camber. -35', +/- 30'. Max 30' difference between wheels.
    Caster. +8° 30', +/- 30'. Max 30' difference between wheels.
    Rear axle
    Toe-in. +25', +/- 10'. Max 20' difference between wheels.
    Camber. -1° 27', +/- 10'. Max 30' difference between wheels.
    Posted 9th Nov 2012 at 21:50
    their alignment computermabob will have all that on it.
    Posted 9th Nov 2012 at 21:59
    daver6
    yeah, our Hunter has everything. You won't be expected to provide your own settings
    Posted 9th Nov 2012 at 22:06
