displaying posts 26 to 36 of 36
Pages (2): 1 [2]
Author Subject: 405 T16 rods & GTi6 crank
I measured an XU7 crank, 24mm, XUD11, 26mm.
Posted 9th Nov 2012 at 10:15
JWP EFi
Turbo Legend!
am i right in thinking the above has an 88 stroke?
Posted 9th Nov 2012 at 16:07
The XUD has an 88mm stroke. Yes
Posted 9th Nov 2012 at 16:08
JWP EFi
Turbo Legend!
stan_306gti6 wrote:
T99PUG wrote:
Yes your correct, they run on ethanol, but still, how do they map the stdf ecu to work with a turbo
Possibly the same way Wayne manages to map the STD ECU for the SC's, using fictious boost I would have thought...
hmmm, ok. but the s/c cars suck through the throttle body as opposed to a turbo setup that blows through it
would be great if i could retain stock ecu obv along with new injectors and map
Posted 9th Nov 2012 at 16:09
luke306rallye
Just to add to this, Wayne has mapped a turbocharged Saxo using the standard ECU.
Posted 9th Nov 2012 at 16:30
nope, stan's wrong, those pair are neither, they are 73 and 92mm.
Posted 9th Nov 2012 at 18:03
JWP EFi
Turbo Legend!
So, it is doable then
Posted 9th Nov 2012 at 18:44
JWP EFi
Turbo Legend!
basically im screwed then, unless i can come across a T16 crank
or do i fit the T16 pistons to a set of RGY/RGX rods?
Posted 9th Nov 2012 at 18:46
andy306gti
I think you could potentially use the standard ECU in one of two ways if my understanding is correct. First would be to disable the map sensor and entirely base your map on the tps or alternatively you could possibly use a map sensor which has the same electrical properties but over a range of pressures that includes positive and negative pressures... although I might also be talking crap.
Posted 9th Nov 2012 at 18:48
JWP EFi
Turbo Legend!
Post #35
see what your saying, but surely with a turbo you'd want to measure load via a map sensor
Posted 9th Nov 2012 at 18:49
andy306gti
Post #36
That would probably be ideal... I didn't say it was perfect just possible.
Posted 9th Nov 2012 at 18:54
Pages (2): 1 [2]
