Author Subject: Could someone confirm these please?
mellowr1
Aft'noon chaps.
Could anyone confirm what these 2 parts are fromUnsure i found them laying in the bottom of the inside of my drivers door along with 2 10mm "flange" nutsDunno
I think the flat plastic thing fits on the window glass somewhereDunno
Posted 8th Nov 2012 at 12:50
smithers
Wait till I get my magnifying glass out Geek
1997 Black GTi6
smithers205 at hotmail.com
Posted 8th Nov 2012 at 12:53
playboyb
What colour is the plastic thing?
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 8th Nov 2012 at 12:56
mellowr1
not sure where the metal clip lives
mellowr1 has attached the following image:
mellowr1
sorry dudes had probs resizing LOL
Posted 8th Nov 2012 at 12:57
playboyb
Hmmmm, someone will be along shortly to confirm what the hell they are lol
Posted 8th Nov 2012 at 13:00
The retaining clip goes over the rubber bung on the window mechanism.
The grey clip attaches to the glass and makes it go up and down straight.
  • Posted 8th Nov 2012 at 13:02
    plastic goes on the trailing edge of the window, but used ones never stay on so buy a new one.
    metal clip goes on the knobble that pokes through the glass on the lifting mech.
    Posted 8th Nov 2012 at 13:04
    mellowr1
    so could these be old ones left in door or would window still functionDunno
    better trawl the FAQ's to see if its window out job Unsure
    CheersThumbs up
    Posted 8th Nov 2012 at 13:09
    Wind the window down and look for the metal clip at the bottom of the window on the end of a rubber grommet. If it's not there - then I'd say it was that one that had fallen off.
  • Posted 8th Nov 2012 at 13:25
    Chris28190
    I hate this part. My window is forever falling out! 4 garages later and myself trying to fix it has resulted in the window always shut and never opened cause its broke yet again! :@
    Cherry Rallye '99 - Sold
    Posted 8th Nov 2012 at 13:34
    If you replace the parts correctly I can't see how it would take 5 attempts.
    Are you using new parts?
  • Posted 8th Nov 2012 at 13:38
    stu
    I've had this problem too, my solution was to go out and buy a new car! Laugh
    mellowr1
    Mine works fine,just found these parts while tryin to find where waters comin inThumbs up
    Posted 8th Nov 2012 at 14:24
    rich306
    Probably a duff seal along the way there somewhere then Wink or one not put back correctly
    Richies Project Rallye
    jamiek_uk2000 wrote:
    - Top Tip!!!
    Posted 8th Nov 2012 at 21:22
    mellowr1
    i found the window front guide rail lower rubber laying in the bottom of the door so refitted thatUnsure
    Dont have any of the foam sealing things though so il see how it goes then maybe buy some of themThumbs up
    Posted 8th Nov 2012 at 21:41
    mellowr1
    couple of more stupid questions just to clarifyUnsure
    The grey plastic guide.........which way does the "sticky out" bit faceUnsure towards outside of door or towards insideDunno
    And
    The rubber bung thingy with the metal clip.......this is found at the bottom of the glass.....which way does the bung go through the glassUnsure from inside to out or outside to inDunno Reason i ask is i had a feel in there and mine's fitted from inside to outside and there aint a lot to get the metal clip ontoCrazy
    Smile
    Posted 26th Nov 2012 at 21:33
    Matt_rallye
    It should go from inside to outside so when it comes to popping the clip in you do it blind as you can't see a f**king thing lol
    Posted 27th Nov 2012 at 09:29
    Matt_rallye
    Posted 27th Nov 2012 at 09:37
    mellowr1
    sounds about rightUnsure
    LOL
    what about the grey guide...anyone know which way this goesDunno
    Posted 27th Nov 2012 at 10:07
    like I said several posts up, goes on the rear edge of the glass.
    Posted 27th Nov 2012 at 10:19
    mellowr1
    yeah i know mate.thanks for thatThumbs up
    But one side has a lip sticking out which could face either inwards or outwardsUnsure if you get what i meanDunno
    Smile
    Posted 27th Nov 2012 at 10:29
    only fits in the rubber seal one way.
    Posted 27th Nov 2012 at 10:39
    mellowr1
    ok cheers Thumbs up Cool
    Posted 27th Nov 2012 at 11:03
    mellowr1
    finally got round to checking this.
    The grey clip on back edge is present as is the metal clip on the bottom bungThumbs up
    Only thing i did find is that when someone previously fixed this they have put the bung in from outside to insideUnsure
    Willl this make any difference?Dunno
    Here's a pic.not that you can see the bungNo
    Posted 31st Dec 2012 at 15:16
