Author Subject: Fuel Swirl Pot
rich_w
I have one of my later style Fuel Swirl Pots up for grabs, as I had to get one made up for someone, and there's no point making just one given the tooling costs etc.
These swirl pots are bespoke designed for the 306; and are essentially upside-down compared to traditional swirl pots.
They are designed to be mounted under the boot floor in place of spare wheel; this location is adjacent to the fuel tank so makes life nice and easy plumbing it in.
Construction is 100% stainless steel - which is essential as its exposed to the elements. The reservoir is internally baffled.
It is designed to use the Bosch 044 pumps, and these, used with this swirl pot will flow enough fuel for 450-500hp, and never give you any fuel starvation.
I can supply the Bosch 044 pump if required too.
£175.
Photos:
Contact Details:
07732 822546
Posted 6th Nov 2012 at 23:32
miles
Just for reference can you do these with the - fittings?
www.pugracing.com
Posted 7th Nov 2012 at 02:32
rich_w
Yes, shouldn't be a problem Smile
Contact Details:
07732 822546
Posted 11th Nov 2012 at 20:09
rich_w
Christmas bump Cool
Contact Details:
07732 822546
Posted 18th Dec 2012 at 18:28
rich_w
Update 8th January 2014:
I need to make up some more of these, as I need one for a high-boost build we are doing.
Does anyone else need one of my Fuel Swirl Pots?
Cheers,
Smile
Contact Details:
07732 822546
Posted 8th Jan 2014 at 12:30
superchargedblack1997gti6
Rich is it worth upgrading the older spec swirl pot do you think? if it is put me down for one?
Posted 8th Jan 2014 at 12:43
rich_w
Ross,
They both do the same job - these are slightly better looking, that's the only difference.
Cheers,
Contact Details:
07732 822546
Posted 8th Jan 2014 at 13:51
I could do with one somewhen but not immediately as I've gotta buy a new clutch and flywheel for my Leon after mapping it. How soon will you need payment?
Posted 8th Jan 2014 at 18:59
rich_w
I'm happy to make one up for you now, however I will need a deposit to secure it? Does that work for you?
Contact Details:
07732 822546
Posted 8th Jan 2014 at 19:13
I can vouch for Pete on this Rich go for it Pete well worth it really good bit of kit
Posted 8th Jan 2014 at 19:59
Sounds good to me, I'll still be after plenty of other bits for going high boost from you at some point as well Rich, head gasket and bolts, shells etc and done advice on injectors and sorting the fueling setup possibly. drop me a PM with how much you want as a deposit as I've got some money in my paypal currently anyway Thumbs up
Posted 9th Jan 2014 at 01:22
rich_w
PM sent Wink
Contact Details:
07732 822546
Posted 9th Jan 2014 at 09:29
rich_w
These are now finished Smile
I have one spare if anyone else needs one...
Cheers,
Rich Smile
Contact Details:
07732 822546
Posted 24th Jan 2014 at 22:02
hugovox
Hi Rich, i need one swirl pot for An6 fittings, con you supply the rubber mounts bolts?
Best regards
Posted 10th Jun 2015 at 19:25
rich_w
I have one of these going spare if anyone is interested - had a couple made up for a project I'm working on.
PM me if interested Thumbs up
Contact Details:
07732 822546
Posted 22nd Mar 2017 at 18:30
devere
Push fittings or an6?
Posted 22nd Mar 2017 at 21:18
rich_w
Push fit.. other fittings could be welded on to the push fit stubs however Smile
Contact Details:
07732 822546
Posted 25th Mar 2017 at 09:59
