displaying posts 1 to 25 of 44
Author Subject: Running Issue
ed_doe
Evening all.
I need some help with an issue I've got with the 6..
I'm so annoyed with it at the moment.
So basically, since doing my oil change three weeks ago, I've had symptoms of a slightly iffy ICV. Only very slight, so i was thinking it may be just that I didn't put the ptfe gasket on straight and it might've been letting a bit of air in.
Anyway, on Wednesday morning the car started stalling when dipping the clutch from any rpms. Stalled like 6times on the way to work which was, needless to say, a collossal pain in the arse. Anyway, after the car sitting idling for a bit in the work carpark and me checking and wiggling the plugs on the throttle body, it seemed totally fine.
Thursday morning it started doing the hunting idle with even the slightest blip on the throttle by the time I got to work. Again, f*cking annoying.
This morning it seemed a bit better, besides a slight wandering idle. It didn't feel completely up to par though, and on the way home it also felt a bit odd. It just seemed to have a LOT of engine braking. There's a hill I normally have to brake down even in 4th, but today it was holding constant speed in 6th on just the engine.... It also seems as a result I'm having to put my foot down a bit more before the engine starts accelerating the car. It just seems in gear there's a larger 'dead spot' than usual. And it's more jerky at light throttle. Before you ask, I've DEFINITELY got the TPS plugged in, and in neutral it revs up fine with no hesitation etc. The issue only seems to be in gear?!
I got home and took the ICV off, took the screws out of it, sprayed a load of brake cleaner in it and all the airways in it, and then reassembled. Also took all the plugs off the tb and put them back on. It certainly idles a little better, and I'll have a good drive of it tomorrow and report back, but imo it's still not right imo...
Anyone have any ideas at all what it could be??
I'm thinking possibly one of the following;
1. Me adjusting to having the cyclones back on with different tyres etc. (I had 17" Speedline Turinis on it before)
2. Me with very thin soled shoes on today meaning my foot was angled further than normal
3. A gammy sensor
4. an exhaust leak (the midbox did hit the remains of a deer in the road pretty hard on Thursday evening on the way back from work??) That and the flames coming out of it a couple of weekends ago couldnt have done it much good...
Any and all help much appreciated, it's really getting me down this.
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 2nd Nov 2012 at 20:36
Sounds like a possible lambda sensor on it's way out to be honest...Yes
Posted 3rd Nov 2012 at 09:07
ed_doe
Hmm I've got a spare, ill get it on the diagnostics today and chuck it on if that's the issue.
Posted 5th Nov 2012 at 10:45
ed_doe
Right, updating this, I put it on the diagnosstic, which pulled up a faulty map sensor. Also appeared the lambda looked a little tired, but was still working.
Replaced the map. Now the response is a bit better, and I'm not using as much throttle to make the same progress, but it's still got masses of engine braking, and it seems to almost hesitate when coming back on the throttle after changing gear. Revs alson fall a lot faster when going from gear to neutral...
It's still not nearly as sharp as it was when blipping the throttle from idle either...
This evening I replaced the TPS with a known working one (off my old engine). It's made no difference at all.
This is completely doing my head in now Sad Any ideas chaps?
Posted 14th Nov 2012 at 19:16
I'm still saying lambda. Yes
Posted 15th Nov 2012 at 15:55
swiftyboi006
^ for sure
Black p3 Love
Posted 15th Nov 2012 at 16:18
swiftyboi006 wrote:
^ for sure
been watching too many F1 interviews LOL
Posted 15th Nov 2012 at 16:52
ed_doe
swiftyboi006 wrote:
^ for sure
LOL
I'd just be surprised if it was the lambda, as it's not been that uneconomical recently...
Posted 15th Nov 2012 at 16:55
As strange as it seems, it is a good possibility as these are classic lambda symptoms. Yes
And you say the diag check did show up that the lambda wasn't in the best of working order.
Try unplugging it and go for a drive. See if there is a noticable difference. Thumbs up
Posted 15th Nov 2012 at 17:55
Niall
Ed stop whinging about it and get your arse up here tomorrow and we will go for a drive with it plugged in. Could be lambda. seemed fine on idle but didnt take the car for a drive so it might not stand up to loading up the engine
Posted 16th Nov 2012 at 22:59
iplay
If you split the mid box check the cat hex core is in one piece.
Posted 17th Nov 2012 at 00:01
cescnathan
If not Lambda, try the MAP Sensor. Thumbs up
Posted 17th Nov 2012 at 03:53
He has already done this:
Posted 17th Nov 2012 at 08:11
cescnathan
oops`~~~didn't read this part Blink
Posted 17th Nov 2012 at 09:26
ed_doe
Right, Plugged it into Pug Planet. No faults logged on the ecu, but the lambda readings at idle wre all over the place, fluctuating between about 28mV & 650mV. As I understand it 500-600mV is about right for idle, and therefore hte 28mV indicates it's running lean?
Basically, I'm pretty concerned at this, and want to get it looked at asap to prevent any damage to the engine.
The issue I have is I'm not going to be able to get parts until the weekend, and realistically I wont get it looked at until early part of next week I don't think...
So my question to you guys; I do about 34miles a day, I've got a 4 day weekend booked off this weekend, so will just drive the missus' car, and will get the car booked to change the lambda on Tuesday next week. Do you think the couple of hundred miles I'll be doing just nursing it to and from work will do any damage? I've obviosly been driving it for a week and a bit since the issues started too, probably done 400miles or so of mixed driving total up to now?
Would it be better to disconnect the lamda all together? IIRC it defaults to a given map which runs a bit rich to prevent any leaning out; can anyone confirm this, and would it therefore be better to potter about with it like this in the short term?
Any help/advice much appreciated!
Cheers all
Posted 19th Nov 2012 at 13:57
Niall
ed, a new lambda should be fluctuating between 400 and 800mv on a gti6. It will be fine as it is for now. its not like your going to be leaving it for months and months.....not that it matters. your engines broken anyway!
Posted 19th Nov 2012 at 16:50
It will be fine until you can get it replaced. Yes
You can unplug it and the ECU will revert to a base map stored within the ECU settings from the factory. Yes
This will indeed as you say, make it run slightly richer. Thumbs up
Posted 19th Nov 2012 at 18:39
ed_doe
Thanks guys Smile ill not rush it all together then, just book it for next week and Potter round until then!
Posted 19th Nov 2012 at 20:05
No problem. Thumbs up
Do try unplugging the lambda though and driving it, if you notice a difference in the car and it drives much better then at least you have confirmed the fault. Smile
Posted 20th Nov 2012 at 07:21
ed_doe
Cheers Stan, I'll give it a go this evening on my way back from work Smile
Posted 20th Nov 2012 at 08:41
No worries, keep us posted on what you find. Thumbs up
Posted 20th Nov 2012 at 11:05
Matt_rallye
Where's the plug for lamda? Might see if it helps mine atall.
Although mine is f**ked with a couple of bent valves haha
Posted 20th Nov 2012 at 11:23
Down behind the battery box, floating about. It's a black 4-pin plug with a sliding red locking bar on it. You need to pull this bar out of the side of the plug and the plug will come apart.
Posted 20th Nov 2012 at 12:29
ed_doe
Righto!
Changed the lambda, it's definitely improved things no end! It's still a little lumpy near the top of the throttle, and almost has a bit of hesitancy when changing gear... I dunno if it's just me being hypersensitive of it now but I don't think it's completely sorted. Now a question; does the icv regulate any airflow when in gear and not on the throttle? Or does it only work when at idle with no throttle? I'm just trying g to work out if I've still got a slightly Dicky icv rather than anything else...
Posted 28th Nov 2012 at 19:18
Glad the lambda has sorted out most of the issues. Thumbs up
The ICV doesn't meter air on the over-run, only when the engine is in an idle state.
If you have slight issues near the top end of the rev range it's probably the MAP playing up, although as you say it could well be in your imagination.
Posted 28th Nov 2012 at 19:25
