Registered on service box but cant find the bit that contains the door seals
its not with the doors section
Im after the small seal that fits across from level with bonnet to under the main door rubber.
ANyone know the part number please
| Author | Subject: Service box part no help |
mellowr1
Senior User Location: Maidstone Registered: 12 Jun 2012 Posts: 995 Status: Offline |
Hi chaps.Registered on service box but cant find the bit that contains the door seals its not with the doors section Im after the small seal that fits across from level with bonnet to under the main door rubber. ANyone know the part number please |
peetypug
Seasoned Pro Location: Spooning marksorrento205 Registered: 20 Feb 2011 Posts: 1,869 Status: Offline |
Welshpug will be along shortly to assist ![]() ________________________________________ Cherry rallye - DOB Thursday 29/04/1999Team Rallye - the leaner, meaner, better looking sister of the GTI6 ![]() roland rat wrote: You sir either live for the 6 or have a mental retardation to still be repairing this! The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental. |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Right, you have two strips available: One leading from bonnet up to the ceiling alongside the windscreen: Left: 9023 L9 Right: 9023 N1 But I think you are more or less referring to the door seal that runs around the frame? If so: 9023 X5 I also have a part no. for the sideskirt seal if you want that ![]() ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
He's after the small 2 inch bit that attaches to the pillar level with the bottom of the windscreen. To the right of the mirror.________________________________________ ![]() |
rich306
If its the rubber seal that is 2 inches long level, then that's part of the first part number i gave. There's nothing else present, even on my car!! check it out on the front pillar part of service box________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
mellowr1
IM A BIT CONFUSED WITH THIS Yes i see the gutter seal which is item 8 on side panel side door frame but the small part i require is definately a seperate part,it plugs into the body and wraps over the seal and tucks under the door seal What is the circled part with the arrow to the gutter seal? On the FRONT ENTRANCE POST AND COWL SIDE diagram what is item number 1 with A+2.Could this not be the offending item? The gutter seal is about £63 so dont really want to pay that for a 2" piece of rubber that "may" not be part of it |
rich306
no.1 is saying Lateral side sill protectors, i have absolutely no idea what you are after lol. Do you have one on the other side that perhaps you could take a photo of and post on here? ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
You said you knew earlier ![]() f**king hell. I'll post you the one I have and you can bond the bas**rd on. ________________________________________ ![]() |
mellowr1
ok chaps.here is the offending item,allbeit the passenger one I've just had my door card off and found a few things; Amongst a couple of flange nuts and some wire clip i found that the front window guide's rubber had gone down the guide and was curled along the bottom of the door inner and that there is no polythene sheet on door to stop water getting into door card I cant see that being the reason the door rubber fills though as the holes in bottom of door are lower than the door seal On a good note all the screws are done up tight now and my auto window wind now works mellowr1 has attached the following image: |
rich306
Lol, the part i thought you were on about in the first place, but it seems that the part on service box could be this 7134 64 I.e. the part that you questioned as being between A+2. ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
no, its not that part number ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
only part that comes close I think could be 9023 K7 / K8________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
playboyb
Seasoned Pro Location: Maidstone Son! Registered: 27 Jun 2011 Posts: 1,464 Status: Offline |
How come it comes up in French when I try and register? Can't find the language selection! s**theads________________________________________ 306 1.8 xs moonstone blue-SOLD306 gti6 supercharged china blue-SOLD 406 coupe D9 3.0 V6-SOLD |
mellowr1
hi sam.it is a pain in the arse.....language bit is bottom left corner m8 |
playboyb
mellowr1 wrote: hi sam. it is a pain in the arse.....language bit is bottom left corner m8 Ta my love ________________________________________ 306 1.8 xs moonstone blue-SOLD306 gti6 supercharged china blue-SOLD 406 coupe D9 3.0 V6-SOLD |
mellowr1
Just in case anyone is interested i got this new rubber part today from pug.It is the part on servicebox called "wrench" and is only couple of quid |
fat lot of good to anyone without the part number though ![]() is it this? 9023 K7 DOOR FRAME SECTION WRENCH LEFT 9023 K8 RIGHT ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
oh yeha, that's what I suggested a few posts up ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mellowr1
welshpug! wrote: fat lot of good to anyone without the part number though ![]() is it this? 9023 K7 DOOR FRAME SECTION WRENCH LEFT 9023 K8 RIGHT CORRECT! 10 points |
