Author Subject: Radiator Fans (track car)
clen666
What fan setup would people recommend for a track car?
I will be using slimline sucker fans mounted on the rad with those ziplock things.
Would two fans be necessary? Or would one fan suffice, as there shouldn't be as much slow speed driving?
10, 11, 12"?
Team 'unintentional rat look'
Posted 30th Oct 2012 at 17:19
you can easily fit a 14 inch of you going single. they have the same cfm as 2 10" too
im going to fit two spals most likely. When jeffers lets me know the size of his :p
Posted 30th Oct 2012 at 17:25
clen666
I was just going to get those fans from car builder solutions as I've heard good things about them.
The spal's flow a bit more according to what I've read, but I don't know if they are worth double the price?
Posted 30th Oct 2012 at 17:55
woody.
Pretty sure I read on here that fans are pretty useless after 40mph...
Posted 30th Oct 2012 at 18:05
daver6
I love radiators too!
Wishbone Polybushes available
Posted 30th Oct 2012 at 18:14
I've only ever had one standard fan on mine, never been a problem.
Posted 30th Oct 2012 at 18:18
clen666
Might just go for one 12", should suit my needs then Thumbs up
Posted 30th Oct 2012 at 18:29
I have 2 X 10" Spal fans on mine and they coped fine with track use etc. Thumbs up
Posted 30th Oct 2012 at 19:29
stan_306gti6 wrote:
I have 2 X 10" Spal fans on mine and it hasn't overheated once in the time it's been parked in my garage
Obligatory.
Posted 30th Oct 2012 at 20:49
jeffers Forum Admin
Sorry I forgot! I'm dusting the car off tomorrow getting ready for Oulton on Friday, il check then! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 30th Oct 2012 at 22:02
cheers Jeffers Smile
Posted 30th Oct 2012 at 22:03
owain wrote:
Obligatory.
That's also a true statement, it certainly hasn't. LOL
Posted 30th Oct 2012 at 22:38
clen666
Stan, I'm thinking 2 fans will probably be unnecessary as I won't be sitting around in city centre traffic or need the extra cooling for the air con (unsure if you still have AC?)
Posted 30th Oct 2012 at 22:41
No AC in my car mate, it got took out when I first went low boost back at the end of 2007. Smile
If the vehicle is solely for track use then I guess one fan will be more than adequate, so you might as well make it a larger one to take advantage of the extra space.
Posted 30th Oct 2012 at 22:53
miles
1 is fine, you can even use a 6" fan which will hold the temp, But as said as soon as you are moving the fans become useless so fitting anymore unless a AC road car, Turbo etc is not worth it
www.pugracing.com
Posted 30th Oct 2012 at 22:58
clen666
Actually miles, mentioning turbo has made me realise there will be an intercooler sitting in front of the rad Doh LOL
In that case, would you recommend two to help airflow?
Posted 30th Oct 2012 at 23:04
The fan should be a "draw through" fitment anyway, so it will pull the air through regardless of an intercooler being in the way. Mine is like this also. Yes
Posted 31st Oct 2012 at 05:58
