displaying posts 1 to 25 of 39
Author Subject: Stalling issue
Batesy86
I've scrolled through numerous threads about stalling issues, all of them seem a bit different so thought i'd just ask my own question...
My issue is intermittent, doesn't seem to have any particular temperature it does it at, ambient or engine. It's when slowing to a stop and dipping the clutch, sometimes it catches on 8/9krpm sometimes it drops lower and doesnt die but mostly it stalls. Now i've obviously read about CTS and ICV and am willing to try them, however nobody has mentioned AC in these threads. If i have the AC on then it NEVER stalls. I don't know if this is because the unit is spinning and holds the engine rpm via the belt, or if when the ac is off something is going wrong?
Any ideas?
Posted 29th Oct 2012 at 18:23
fatlapit
the ecu raises the revs at low revs to stop it stalling, when a/c not on it relies on the icv to stop stalling, so sounds to me that you need to clean your icv out
Posted 29th Oct 2012 at 18:26
Batesy86
I've tried cleaning it with some wd40 and brake cleaner but didn't help the issue. I've also tried a new air intake temp sensor with no avail.
Posted 29th Oct 2012 at 18:39
fatlapit
spark plugs?????
Posted 29th Oct 2012 at 18:40
There's loads to try tbh.
PAS Sensor can cause issues by not compensating for the rack being used or sending a load of bs to the ecu.
ICV
MAP sensor
and so on.
They are the main three though
Posted 29th Oct 2012 at 18:43
PAS sensor is a good shout, but the ICV is the main one. Yes
I would recommend a proper clean of that ICV, and if that doesn't solve the issue then it's probably time for a new one. Wink
Posted 29th Oct 2012 at 19:08
bas_306gti
had this on a 306 GTi engine once, replaced the ICV, TPS, MAP, lambda; eventually it was due to massive carbon buildup inside the engine and inlet manifold/throttle housing, mainly caused by bad petrol
Posted 29th Oct 2012 at 20:15
Batesy86
I've read that unplugging the pas sensor is a good way of telling of that's the prob. If it cures it what's the negative to leaving it unplugged for good?
Posted 30th Oct 2012 at 10:39
fatlapit
its another anti stall job for when your manouvering and streering
Posted 30th Oct 2012 at 10:44
If that does cure the issue I wouldn't worry about replacing it too much. A lot of people have unplugged faulty ones and never had any issues from doing so. Smile
Posted 30th Oct 2012 at 14:47
bas_306gti
The steering sensor is not absolutely necessary, the engine just drops a little in revs when you are turning at idle, the XSI 16V for instance doesn't have the steering sensor
Posted 30th Oct 2012 at 18:57
Batesy86
I unplugged it before driving home, didn't have any stalling but it came close once or twice still. Do I need to reset or anything or just unplugging do the job?
Posted 30th Oct 2012 at 19:10
You don't need to reset anything, just leave it like that for a few days and see what happens. Yes
Posted 30th Oct 2012 at 19:24
Batesy86
Cool will do, let you know how I get on
Posted 31st Oct 2012 at 10:17
Batesy86
Hasn't stopped it. Icv next...
Posted 2nd Nov 2012 at 17:42
It's probably a good idea, these things do get clogged up and wear out over time. One piece of advice, get a genuine one even though it costs a lot. The eBay cheapies don't last that long unfortunately. Sad
Posted 2nd Nov 2012 at 19:18
Batesy86
How much is a pug one?
Posted 2nd Nov 2012 at 22:45
bas_306gti
about 140 pounds for a OE peugeot, 100 pounds for a VDO, 35 pounds for a ebay one......
Posted 2nd Nov 2012 at 23:04
Batesy86
Woah! Afraid it might have to be an eBay job then, if it clears the problem I can then save for a decent one!
Posted 3rd Nov 2012 at 11:08
Batesy86
What about leaving mine soaking in wd40 for a night?
bas_306gti
Yeah, take the steppermotor from the housing and give them both a good clean with WD40 or a degreaser, check for leaks (O-ring, the connecting hose etc) and check if the wires/connector are OK.
If nothing of the above helps, you've got to buy a new one.
Posted 3rd Nov 2012 at 11:56
Totally agree with this. ^^
Posted 3rd Nov 2012 at 15:26
Batesy86
Today, I plugged the modis diagnostic in at work, it came up with an O2 sensor fault. Cleared it, but I presume I need a new one. Expensive from pug? Presume it's worth getting a genuine?
Posted 6th Dec 2012 at 10:10
It's a Bosch sensor the genuine one. Yes
You can get it from Pug, they are around £140 but you can get the identical sensor from a Bosch stockist for probably half the price.
Posted 6th Dec 2012 at 16:14
Batesy86
ECP are quoting £59 for a Bosch Smile
Posted 6th Dec 2012 at 16:26
