Author Subject: 4 pin window switch / CTS / ICV
Batesy86
I'm after a 4 pin elec window switch for drivers side please.
Also the green cts for the thermostat housing.
And a ICV.
All to fit a '97 '6.
Thanks!
Posted 28th Oct 2012 at 08:53
R561MMO
have a leccy window switch will do ur job i think came from a 97 306
Posted 28th Oct 2012 at 12:20
snjbowk
ive got green sensor and window switch off ph3.£15 delivered?
breaking moonstone v plate 6!!!
Posted 28th Oct 2012 at 12:32
Batesy86
Is the switch 4 pin though guys?
Posted 28th Oct 2012 at 12:41
6waysforward
Take the window switch apart, clean the connections and put it back together. Works everytime. Unless you's is fooked. Thumbs up
Posted 28th Oct 2012 at 18:55
Batesy86
The control for passenger side works fine, and drivers side goes down fine, just takes about 50 tries to go back up!
Posted 28th Oct 2012 at 22:50
6waysforward
Clean the terminals mate honestly. Mine did it on 2 of my cars.
Be carefull though as there are a few little springs.
Posted 29th Oct 2012 at 01:08
Batesy86
If I take the unit out, seperate the two halves are the terminals then obviously visible?
Posted 29th Oct 2012 at 08:45
what do you mean 4 pin switch? what's the differences? i bought a gti6 driver side switch for my HDI but it doesn't support one-touch so it's no good to me - looks like the gti6 is 7 pin and the HDI was 6 pin (iirc). yours for a couple of quid posted. standard gti6 item..
Posted 29th Oct 2012 at 08:47
Batesy86
Where the multi plug connects to, it's got to have 4 pins on the bottom row. I've tried ones with more and it doesn't work...
Posted 29th Oct 2012 at 10:36
tbh i would think any one-touch gti6 one would work, i tried a gti6 one on my hdi like i said and it blew the fuse. on further inspection it's got more pins on the gti6 on than the hdi one
can check mine for you though
Posted 29th Oct 2012 at 10:39
