Author Subject: Blowers not working
Batesy86
I've been on the search but nothing really helped me out...
So as some may know I've just done the clutch on the 6, now though after around 2 weeks with battery off the blowers aren't working. Fuses have power and the motor has a good earth and power on the red wire. The blue/red doesn't have power, and even if I bridge it with the red the motor doesn't spin. Does this only mean that the motor is bust?
Posted 25th Oct 2012 at 19:01
Try putting 12v direct to the motor and see if it spins up, at least you can eliminate it this way. Yes
Posted 25th Oct 2012 at 20:10
Batesy86
Bridging that permanent live is the same thing isn't it?
Posted 25th Oct 2012 at 22:34
Doh
Reading fail...yes it is mate. I guess the motor has had it then. Take it out and see if you can power it and flick it by hand to see if it will start to spin. It could be stuck brushes, would be a shame to fork out for a new one if it just needed a helpful hand. Thumbs up
Posted 26th Oct 2012 at 12:22
Batesy86
Ill give that a go over the weekend, cheers.
Posted 26th Oct 2012 at 14:34
If you find you need a motor when you've had a look, give me a shout. I have one here.
  • Posted 26th Oct 2012 at 14:40
    Batesy86
    Will do, thanks!
    Posted 26th Oct 2012 at 15:39
    Batesy86
    I unscrewed the motor, spun it by hand and it started working! Screwed it back up but it now makes a racket like its catching on something!
    Posted 27th Oct 2012 at 11:57
    Batesy86
    Took it apart and it's like the motor clicks at a certain point in its spin, hardly audible, until its spinning round rapidly!
    Posted 27th Oct 2012 at 17:36
    It probably was stuck/worn brushes then. Yes
    It could always be a dry bearing. I can't remember off the top of my head, can you easily get at the bearings to maybe drop a small drop of oil on them?
    Posted 27th Oct 2012 at 19:03
