displaying posts 1 to 25 of 60
Pages (3): [1] 2 3
Author Subject: Unlocked ecu
tony1991
I have just got a black rallye of eBay. It's a none runner the guy changed the stem seals and ecu locked its self, so now fitted a unlocked ecu but still not running it almost wants to start, do the unlocked ecu need coding
Any ideas thanks
Posted 24th Oct 2012 at 21:32
Niall
ECUs can not lock them selfs. If its been unlocked, it does not need coding to the BSI.
Im assuming you have started with the basics and checked all the sensors are plugged in?
Posted 24th Oct 2012 at 22:52
tony1991
Checked all sensors, the only thing I have found so far is fuel cut switch was no attached and is damaged on the connection so first thing is to get new one of those fitted, after that I will try compression and sparks
It almost wants to go but just not quite thinking timing may be a little bit out
Posted 25th Oct 2012 at 22:45
can't you just bridge the inertia cutout switch to disable it?
Posted 25th Oct 2012 at 22:47
Niall
yep just join the cables and its wired out.
Posted 25th Oct 2012 at 22:55
tony1991
Thanks I will try that tomorow
Posted 26th Oct 2012 at 10:26
tony1991
I have wired enertia cut off switch cables together, checked fuel pump with 12v which made fuel purge to engine, swapped relay with my red rallye which is working, checked fuse which is ok, But still won't start. I also swapped back to the ecu that was (apparently) locked and they both do the same thing, tbh I don't no what a locked one is supposed to do/no do?
If an ECU is locked then does it prevent power to fuel pump/spark plugs?
Any ideas thanks
P.s this is a friend of Tony who has asked me to proof read this post because apparently you guys rip him for his bad english.. Wink
Posted 27th Oct 2012 at 19:54
jackalk8
inertia* Wink
Posted 27th Oct 2012 at 20:51
tony1991
Ecu works fine on my other rallye so can't that
Posted 28th Oct 2012 at 16:10
bas_306gti
The ECU is locked inside (in the software) it won't send any signals to injection/ignition until it is unlocked again.
You only can unlock the ECU if you have a ECU with the corresponding immobiliser module and keychip or if you have a unlocked ECU and cut the wires tp the pins 48 and 27 on the ECU before refitting
Posted 28th Oct 2012 at 18:29
tony1991
But I tried this ECU in my other rallye an fired up and ran fine
Posted 28th Oct 2012 at 20:24
bas_306gti
Then your problem is not a locked ECU.
can you hear the fuel pump upon startup?
Posted 28th Oct 2012 at 21:58
tony1991
No I can't, tried 12v to it an it works, relay I swapped with other rallye and works fine, fuse is all good
Bit stuck really with what to try next
Posted 28th Oct 2012 at 22:07
bas_306gti
Does the engine start when you put 12V on the pump?
Posted 29th Oct 2012 at 20:04
tony1991
No it doesn't, is there any sensors within the plug connecting the fuel pump. Next step I think is check plugs,compression, and if I can get the pump working on its own then I will have timing checked.
What ever I have got a pretty cheap black shell even if I har to change engine
Posted 29th Oct 2012 at 20:37
bas_306gti
does the engine crank over when you turn the key ?
is there a spark when you crank the engine ?
Posted 29th Oct 2012 at 21:10
tony1991
Yer engine cranks over just won't start it's not far from starting by the sounds of it.
Posted 29th Oct 2012 at 21:32
bas_306gti
When you crank the engine, have a somebody check if there's a spark from one of the plugs, if you don't have a spark check RPM sensor
Posted 29th Oct 2012 at 22:13
tvrfan007
Cam or crank sensor are likely culprits as eluded to above. 12V to the starter is required to crank, 12V to everything else is required to start!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 3rd Nov 2012 at 15:08
your other rallye, does that still have its transponder box connected? same goes for the one that wont start.
Posted 3rd Nov 2012 at 15:16
As said above, you need to check whether you have a spark. Yes
This will enable you to eliminate the immobiliser and crank sensor. Smile
Posted 3rd Nov 2012 at 15:51
tony1991
I have changed the crank sensor for one I had on my old engine out of other rallye which worked , but still no spark the plugs look pretty dry and corroded
Posted 3rd Nov 2012 at 19:53
OI TONY!
so?
Posted 3rd Nov 2012 at 20:02
tony1991
Where will I find the transponder unit, my other rallye is 100% standard so should think its still fitted, just a fort could the timing be ever so slightly out
Any work that was done on the engine was very poor from I can see several bolts lose and a lot missing so thinking the guy may have set the timing wrong
Posted 3rd Nov 2012 at 20:10
EPIC PALM + FACE MOMENT.
without removing the transponder unit from under the dash (in front of the gearstick console) your "unlocked" ecu from the other Rallye will simply lock when you turn the ignition on, unless its a professionally unlocked ecu with cut pins.
Posted 3rd Nov 2012 at 20:12
Pages (3): [1] 2 3
