Author Subject: Quickshift
306 Rxs
For sale, my quickshift with a new higher base, making it shorter and closer to the steering wheel, without loosing any of the correct/mechanic feel.
In the lower end, the original plastic bush was replaced by two roller bearings, eliminating any possible material wear.
It uses a constella quickshift with stronger bearings.
It's as new as it gets, only has a couple of hours of use.
Gearknob is a Sparco Carlos Sainz edition.
I want to sell it due to the swap for honda engine, wich uses a cable setup.
100pounds. (115 delivered to uk)
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 22nd Oct 2012 at 03:55
gti6girl
How does reverse work?
Posted 22nd Oct 2012 at 07:20
vts_tibi
I guess it may only work with the 5 speed box?
VTS
best 60' : 2.272
Team Trackday™
Posted 22nd Oct 2012 at 08:21
306 Rxs
exactly.
if you want to use it on a 6speed gearbox, you'll have to adapt the cable to the quickshift.
What is a hybrid?
Posted 22nd Oct 2012 at 10:33
306 Rxs
SOLD for a member of the club.
What is a hybrid?
Posted 22nd Oct 2012 at 11:10
