The problem with low boost is that it is so smooth that if you aren't screaming it, the only way that you notice is that the speedo moves faster. Which makes you itch for more power.
I got rid of my charger because I got done for speeding and knew that if I kept it more points would follow.
I notice that you are quick to slag SC-6s off. I will be interested if you could make an off the shelf turbo conversion that is as reliable and cheaper yet produces the same power.
Every turbo conversion that I have seen on here has turned into a money pit and hasn't been faster, cheaper or more reliable than a comparable supercharger conversion.
I will be impressed if someone makes a reliable turbo conversion giving ~250bhp (using new stuff) for £4k drive in drive out.
Ex SC-6Now in a Megane R26
smegal
i may be wrong . The supercharger set up is ace for usable power. That why it's so popular.
R888's at least with that surely.
